585,753 active members*
4,422 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Older Haas DIY cheap Probe - Guide with pics and video
Page 1 of 2 12
Results 1 to 20 of 38
    Aug 2013
    Cool Older Haas DIY cheap Probe - Guide with pics and video
    Hi!
    My first post on this forum. But been reading for quite some time, and this forum got a lot of useful information for a n00b like me
    First off. sorry for my bad english
    So the story goes -> built a mach 3 cnc mill and got tierd of it.. Came across a haas 1996 vf-2 for a reasonable price, and ended up buying and restoring it.
    One thing i really loved about the mach 3 setup was the probe stuff. It made it so simple to probe a bore or position the rotary table and set work offsets, so i was really missing the probe on the haas.
    Since i bought the machine for like 6000$ USD including the 4th axsis rotary table, you get that the budget is not to high, as it`s more of a hobby machine for me now, then anything else.
    I did look into the reneshaw probing systems and stuff, and that would kinda blow my whole "tooling budget". So i was looking for a cheaper option.
    There`s not a problem finding useful information about the reneshaw stuff, but the DIY stuff is much harder to find on these machines, since they are mostly in production compared to mach3 hobby machines.
    So here goes:
    Fist off, i had to figure out the SKIP signal stuff. Since i did not know anything about the skip function, i had to collect the information here and there. So for you out there that`s in the same boat as me, and know nothing about the SKIP , I`ll quickly explain.
    The SKIP signal is an input signal used i combination with some Gcodes, to stop the machine when the SKIP signal is broken or recived (depending on inverted signal or not)
    So the Gcode: G54 G36 X10.0 F50 will move the probe to X10 or stop the probe if it touch something. It then automatically ZERO your G54 at this spot.
    So what I did was to find two wires, connect them to the SKIP input pins on the I/O board and short the wires together, when watching the SKIP input
    Here you can see where to connect the pins. I just stole the "connector" from an old CPU computer fan i had. It fits right on there
    It`s marked 1070 P47 on the I/O board, on the backside of the connector not shown in the pic, it`s says "skip"
    Attachment 334726
    Watching the skip-signal change when shorting the wires together - you will find this under diagnostics -> descrete inputs
    Attachment 334724
    You can invert the skip signal, depending on what style probe you got.
    Attachment 334728
    I Just bought a cheap one off ebay called TP-1000 . I liked the design of the adjusting screws on this one, so that`s my only reason for buing it compared to anyother I found out there.
    Attachment 334730
    Next step was to wire up the probe. I simply did that by using some "ev1 injector connectors" i had laying around the shop. My plan was to use a minijack, but could not find one, and did not feel like going to the store
    Attachment 334732
    Attachment 334734
    Almost eveywhere I was reading regarding probe stuff, Macros where mentioned. So I was a bit confued whether or not i needed the macro option installed to get this to work properly. I dont have the macro option installed on my machine.
    So far so good, I manage to use the G-codes without any Macros, alteast to do the most common probing stuff like bore center and simple work offsets.
    Here`s a small video showing the probe in action:
    https://youtu.be/tLi1rmDhHI4
    And I`ll end this with some code exampels:
    G31 (stores the probed point to memory, used with M75)
    G36 Automatic work offset measurement
    G37 Automatic tool length offset measurement
    G136 is verry useful. Uses the value stored with G31 M75, and the value meassured with G136, and dived`s that in two. to find the center point.
    SO to find center of X in a bore and store that as G54 (I run Metric on my machine, so just a note if the speeds looks a bit off):
    o00002
    G91
    G54
    G31 X30. F1000. (runs in x axis and stop when probe touched something, or 30mm is reached)
    G01 X-1. F200. (goes back to clear the workpice befor a slow measurement is done)
    G31 X1.5 F20. M75 (does the measurement at slow speed, and stores the meassured X value in the memory to be used for later)
    G01 X-1. F200. (clear workpice again)
    G31 X-60. F1000. (rapids over to the other side of the bore, and stops when probe touches)
    G01 X1. F200. (clear workpice)
    G136 X-1.5 F20. (slowly meassure workpice and automatically set the work offset to center of the two sides meassured, using the M75 stored value from the opposite side)
    G01 X1.0 F200. (Clear workpice)
    G90;
    G01 X0. F500. ( travel to center of what`s just meassured)
    M30
    Repeat the process for the Y axsis if you want to find the center of a bore/pocket/slot
    For finding an edge or corner of the workpice, use G36, as this will set the work offset directly when the probe touch. Remeber to set the stylus offset under settings 59-62.
    Attachment 334766
    Hope some will find this usefull
    Sorry for all the photos beeing flipped sideways allmost breaking your neck
    Re: Older Haas DIY cheap Probe - Guide with pics and video
    That is really, really good work! My hat is off to you. For all the flash and show along with the price tags that accompany those set ups, for you to have accomplished this the way you have is very good work! Kudos to you. I have a Haimer 3D Taster for an older Haas that they said could not support their probe kit. After reading this, I may just do what you have outlined. Again - Well done.
    Aug 2013
    You should go ahead and do it yourself. It takes 1hr to do it, when you know how. And 14 days when you dont
    I`m allso using the 3D taster. What i actually do when probing, is that I offset the probed Z value with the length difference using the G10. So when I put in the 3d taster and jog to Z0, the 3d taster shows 0 aswell. This is nice since all my tool-lengths are based on the 3d taster (tool one)
    Jan 2008
    This thread is so great.
    I am ordering 2 TP-100's right now. I am thinking I can wire them up in parallel to the SKIPS as you have and use one for Tool setter and 1 for probing.
    I do not have macros either so I am super curious if this works for both.
    Quote Originally Posted by reidar85 View Post
    Hi!
    So here goes:
    Attachment 334726
    Attachment 334724
    Attachment 334728
    Attachment 334730
    Attachment 334732
    Attachment 334734
    o00002
    G91
    G54
    G90;
    M30
    Attachment 334766
    Hi! I know im picking up on an old thread but i see you connected 3 wires while mentioning you only had to short two. What is this third wire used for? And which of the three are used for the switch?
    My haas motherboard has a 4 pin connector for skip signal, do you perhaps know the pinout for this?
    Thanks!
    Aug 2007
    701
    This thread was immensely helpful in setting up a cheapo probe on my 2013 VF1 (no macro option). Rather than drop the $8k to the HFO for a renishaw I figured I'd try this out.
    I also used one of those magnetic usb connectors - so I could leave the probe in the tool changer and just magnetically connect it to the wire.
    Things seem to work pretty well, once in a while during probing routine all the axes will move backwards, even though hand jogging works correctly.
    Here are my probing routines if anyone is interested: https://www.dropbox.com/sh/3irjikyol...-zw9K-9la?dl=0
    Question on probing Z, using the G36 Z-1 command - is there anything special I need to do other than have the tool height set properly in the tool table?
    And should the G54 Z work offset read 0, regardless of which tool is loaded up and jogged down to the top of the part?
    Sorry for the newb questions.
    Attachment 445666
    https://vimeo.com/user62335169/revie...040/2a3aa22500
    Oct 2009
    482
    Brian,
    Would this work on our Novakons as well?
    Aug 2007
    701
    You mean the quick connect - yeah for sure. Prob not as much of an issue since it doesnt have a tool changer. But on the haas its nice to leave the probe in the changer.
    Mar 2013
    66
    Quote Originally Posted by brianbonedoc View Post
    Attachment 445666
    How did you calibrate your probe offsets in 59-63? I cannot get the haas 9999 calibrate to function correctly on my old 1997 machine.
    BTW Your dropbox programs are GREAT! Thanks!
    Aug 2007
    701
    It was kinda ghetto, but what I did was take a know bore and probe to center it. Then manually jogged over and read how much it moved in each direction.
    I entered the probe offsets x-/x+ etc, such that it when I reprobed it manually jogging would yield equal results in all directions. I think it's within 2 thou or so on my setup. For me its more about getting the corners and center of the bore, since we cant really do in program measurements without macros. But setting XYZ offsets and tool offsets is awesome. Oh yeah, I added tool length offset measurement too.
    Feb 2006
    17
    Hey Brian.
    Do you have some pics of the wiring you did for the hook up on the 2013?
    Feb 2006
    17
    Brian,
    If you have time a step by step on what you did on the newer haas would be awesome. Have a 2012 vf3 I would like to set this up on.
    Aug 2007
    701
    The wiring is pretty simple. P22 has 4 pins. Only the top 2 pins are needed. I think the top (Pin 1) is +12v I cant remember. Then Pin 2 is gnd - if you short the 2 pins you get the "skip signal"
    For just the probe I wired the 2 wires from pin 1,2 and a attached it to a magnetic usb cable which connects to the probe. Some probes have a diode so if it doesnt work just reverse the 2 wires.
    Here is my new MP3 probe which is much smoother and more consistent.
    Attachment 451032
    https://vimeo.com/user62335169/revie...195/55c401fc26
    Aug 2007
    701
    To add the tool setter I used the built in relay in the picture - the far right one. You can see my 3 wires attached red/grn/yellow. Attachment 451034
    I took the +12v pin from P22 (pin1 I think) and sent it to the relay, the normal closed position connects it to the probe, and the NO position connects the +12v to the tool setter.
    Then when you command M55 the relay switches to the tool setter, you run the code and then M56 turns the relay off setting the connection back to the probe.
    Here is a sample code to measure tool height on the tool setter:
    O03302;
    (T2 Measure);
    T2 M06
    G00 G90 G59 X0 Y0
    G43 H02
    M55
    G04 P0.05
    G37 H02 Z0 F50. (Z0 is activated probe surface, use G59 Z offset to control probe height)
    G91 G01 Z.1 F100.
    G37 H02 Z0 F3.
    G91 G01 Z.1 F100.
    M56
    G53 G0 Z10.
    M30
    Aug 2007
    701
    Here are my probing routines. Because I dont have macros, I had to write a probing routine for each scenario, and one for each tool number to measure the tools.
    Feb 2006
    17
    Thanks for posting that stuff. What toolsetter did you end up using?
    Sep 2005
    20
    Curious, how are you setting tool offsets with just a probe and no "tool offset" measuring device. Oh, and thanks for the great info, plan on doing the same on my 96 VF2!
    Aug 2007
    701
    Quote Originally Posted by gulliver22 View Post
    I do have a tool setting device. It was one off Aliexpress I think - similar to this one as theyre all the same: https://www.aliexpress.com/item/3285...archweb201603_
    I used the relay built in to switch between the MP3 probe and the tool setter.
    I cant' tell you how awesome it is when I change or break a tool, just to run the program to measure the new tool automatically.
    Sep 2005
    20
    Awesome! I'll get me one of those also! Thanks so much!
    Apr 2013
    23
    Hi Everyone, i hope you can point me in the right direction.
    I have a Haas Mini Mill Built 2002 with a CHC control and software version 11.17
    im having trouble finding the SKIP input on the diagnostic screen, my display lists the discrete inputs slightly different to that shown above.
    i can see the Invert skip option but not the actual input itself. i dont know if it will work without actually showing the input or not, bit scary pretending to probe something on the off chance its not there.
    any help would be greatfuly accepted
Page 1 of 2 12
  1. Touch probe for older model machines
    By GITRDUN in forum Haas Mills
    Last Post: 11-30-2015, 09:59 PM
  2. older video of use of WCS
    By cadcam in forum Mastercam
    Last Post: 04-13-2012, 05:06 PM
  3. Older MaxNC w/ Z Axis probe??
    By tim_j in forum DIY CNC Router Table Machines
    Last Post: 08-31-2010, 08:15 PM
  4. Got my first CNC today. Older HobbyCNC *Pics 8-31
    By hcsceo in forum DIY CNC Router Table Machines
    Last Post: 09-14-2009, 02:28 PM
