Hi All,
Got the old Harbor Freight mini last year and the forever famous HOSS Freak conversion got me roped in.
So my take on this was to convert without using ball screws and go with 5/8 precision ACME 8-1from Mcmaster Carr and home made Delrin bushings and belt reduction. I had read a post on making these zero backlash bushings so I got a box of cuttoffs of 2" dia by around 3-4" long pieces cheap plus 6' of ACME for $43 from Mcmasters and away we went.
Machine specs are KL23H276-30-4A 282oz steppers with Leadshine DM856 drivers off of Ebay $42ea and a $12 BOB off ebay that seems to work fine. I have a PMDX-122 if it doesn't but I wanted to see if these cheap boards work out. I have a 70V toroidal power supply from Anek and for now I'm running the 5V and the 12v for the BOB off of wall warts. Anek modules for the 12V and 5V are on the way. Running 2.75 reduction on the X and Y with 2.25 on the Z. I got the longer Y base from LMS and spaced the head out 1" to match.
I have plastic gears on it for now as I couldn't find what I really need in metal since one of the points of this build was to be able to do it without a lathe to turn down the screws. Once I'm fully up and running I'll cut my own with a 4/5 axis I designed to prove the concept. The concept was could someone with just a drill press, and chop saw and a dremel build the CNC parts and have a good base to move forward after and then make the other parts.
So far everything has worked out very well and I'm at the stage of working through the electronics. The Delrin bushings are everything you could ask if they last in use. The only snag so far is the bushings are pretty tight and the motors are losing steps some of the time due to this.... I think..... but...... tonight while at work I figured out I don't have the settings for the steppers set right in Mach3 and that may be part of the problem. I was amazed that after doing the math that the X and Y are 44000 steps per inch with 10 micro steps set on this build. I didn't have anything near that in Mach so we'll see what the steppers do once I have the correct values for things on the drivers and in Mach.
Or it could be that the gear reduction doesn't give me the torque advantage I was hoping for and I'll have to upgrade the steppers from 282oz to something better or the drivers are cheap knockoffs and don't run the steppers correctly. I'll get it figured out.
Of course here are some pics
