585,556 active members*
3,632 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc OM model A (parameters) Error ATC
    Jan 2016
    13
    Good day.
    I have old milling machine Leadwell 1300D with fanuc OM model A (1987).
    I lost the parameters and macro programs. I found only old parameters ( that not original, but machine worked) and rewrite them.
    Now I can:
    - send machine in home position,
    - use drilling cycle (with one tool)))
    - In MDI i can change the tool use manual code
    M9
    M19
    M21(RIGHT)
    M26(UNCLAPM)
    M24(DOWN)
    M11(MAGAZIN CW M12-CCW)
    M23(UP)
    M25(CLAMP)
    M22(LEFT)
    So it's work ok...
    But M6T() in MDI doesn't work and make error 1039 TOOL NO. > 20 !!!
    In auto mode i can't change the tools.
    I can't understand how is working ATC. I don't found macro program for tool changing and don't found parameters that call sup program ( i mean #230-239 =6 calls pr. 9020-9029 #240-242=6 pr.9001-9003 #6080-6089=6 pr.-9020-9029)
    Number of my parameters
    #100-219
    #500-599
    #700-779
    #900-919
    #1000-1128
    #2000-2128
    #3000-3128
    #9000-9008
    #9700-9899
    Not a lot.
    From my point of view machine don't used macro program for tool changing. Because absent parameter that connected with macro program.
    If machine don't used macro program for ATC, how it works?? Ladder (logic) ? Why error?
    May some one help me?
    Dec 2009
    952
    Re: Fanuc OM model A (parameters) Error ATC
    create a new program
    O9001:
    G40G80
    G0G91G28Z0.
    M19
    T#4120
    M6
    M99
    After finish try to change in auto
    Jan 2016
    13
    I wrote parameters from machine with 4 axis( I have just 3 axis), with changing some parameters that making error. Wrote simple macro program and nothing!! I will write old parameters and check with macro.
    I can't sent macro program by DNC conection, PS 87 error ( problem with DNC settings) .
    I use steps:
    mode MDI
    key PARAM/DGNS
    the PWE=1 ("1" then INPUT)
    set parameter 10 to: xxx0xxxx
    CAN+RESET to cancel alarm
    mode EDIT, the PRGM key
    digit "O9001" the INPUT key, the LSK flash in lower right corner
    Send the file in PC
    confirm the 9001 program is in the memory
    Return PWE=0 in MDI mode.
    Parameters communication software is ok!
    Another programs, i can sent without problem.
    I will try, rewrite parameters and try again!!
  1. Replies: 0
    Last Post: 09-07-2013, 11:05 AM
  2. FANUC 0T Model C Parameters
    By gbowne1 in forum Fanuc
    Last Post: 09-11-2012, 01:29 AM
  3. Help with FANUC 0i-Model A (servo parameters)
    By mr_electrician in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 07:28 PM
  4. Fanuc 2T Model-A Parameters
    By jeffascher in forum Fanuc
    Last Post: 12-28-2005, 07:51 PM
  5. Fanuc 3T -MODEL A error 5
    By geroda in forum Fanuc
    Last Post: 07-08-2005, 02:39 PM
