586,005 active members*
5,191 visitors online*
    Sep 2016
    Pulling my hair out!!! Lasercut 5.3
    Hi guys,
    I've recently found this forum and kudos to you all
    I'm trying to help a friend out with his laser cutter. Its a senfeng which is 120 x 90cm bed.
    Hes had it for a couple of years now and seems quite competent in using it.
    This is when I come in. I'm more computer savvy being a graphic designer, Im in front of a computer all day for my sins. Anyway hes recently got a new pc and wantslasercut 5.3 put onto his new machine. Ifound it from a site blog.justaddsharks.co.uk/installing-lasercut-5-3/
    Not sure if its legit or not or I should be getting a more solid download? :s
    I downloaded it, installed it, attached the dongle and cableto the pc and it all seems like the laser cutter and pc are communicating witheach other correctly. I installed thedrivers and followed the protocol that you get online.
    The issues he is facing which are different to what he wasdealing with before are:
    1, his laser cutter will only move half way now up the bed onits axis, liturally stops and wont go any further?
    2, The laser seams a lot weaker than what it was previouslylike it wont cut through etc on the same speed and strength?
    3, I believe he alsosaid that the laser is cutting from a different angle like its landscapesuppose to portrait if that makes sense.
    Apologies if this all sounds a bit wishy washy and ivemissed some info out that’s crucuial for you pros to diagnose.
    Any help, advice or literally anything would be immenselyand humbly appreciated.
    Many thanks in advance
    Gareth
    Feb 2009
    6028
    Re: Pulling my hair out!!! Lasercut 5.3
    You will probably need to set the board type in the set up. Without doing that, speeds and size will be off.
    Sent from my A3-A20FHD using Tapatalk
  1. pulling my hair out
    By joey414 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-07-2013, 10:14 PM
  2. Mach 3 pulling hair out :( help
    By Tacomatrx450 in forum Mach Mill
    Last Post: 11-12-2012, 03:14 AM
  3. FLA-200 Linear Bearings Pulling my hair out!
    By crash5050 in forum Open Source CNC Machine Designs
    Last Post: 05-07-2011, 05:31 AM
  4. pulling hair out
    By radioman in forum DIY CNC Router Table Machines
    Last Post: 01-05-2010, 10:16 PM
  5. 203V Pulling my hair out!!
    By WilliamD in forum Gecko Drives
    Last Post: 04-18-2008, 07:09 AM
