585,977 active members*
4,352 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > aspire with vision series 2 controller
Results 1 to 9 of 9
    Mar 2011
    Hi, I am a newbie here. any help is much appreciated. I am trying to send tool path files from Vectric Aspire to send a job to a vision 2448 using a series 2 controller. I am using a windows 7 laptop with a usb/serial converter. I have used this machine with engrave lab with no problems. Engrave lab uses a hot folder to get the files to the controller. as soon as you send the job, the light on the controller instantly starts flashing and the machine is ready to cut. I have not been able to successfully get the tool paths from aspire to the vision series 2. I have tried saving the files directly to the hot folder for engrave lab, I have tried gcode sender, universal gcode sender and too many other things to list. I am at a loss...
    Nov 2015
    5
    Quote Originally Posted by asparky99 View Post
    I was wondering about doing 3D engraving with our 1624. Considering this post is 2 years old and never replied to, I guess it can’t be done.
    Aug 2012
    10
    Re: aspire with vision series 2 controller
    Quote Originally Posted by tooler82 View Post
    Vectric Aspire > output toolpath as txt file > make sure serial connection manager is active for vision machine tools > open motion mechanic from machine tools > click "file" the "send file" select txt file you created.. Series 2 controller should be blinking saying its ready to start the program.
    Jul 2017
    348
    i have an old vision ve 810 engraver and i use vectric aspire to create the toolpath and i send it to the engraver and it works great..i can help someone if needed
    Quote Originally Posted by Shelby5041 View Post
    Hi Shelby,
    I have a vision 24 S2 and don't know how to send from Vcarve. Do you need any other software or utility from Vision? My machine comes with no software but Vcarve.
    Jul 2017
    348
    i cant find any info on that vision model number are you sure its correct?
    Jul 2017
    348
    i connect my vision ve810 engraver via serial part and use vectric to create toolpath using vision series 1/2 post processor and then i send toolpath directly to machine via output to machine in vectric aspire
    Nov 2022
    So I hate to bump an old thread, but I'm attempting to use aspire with my Vision 2448 Router and I'm not seeing it as an option for a post processor. Where are you guys finding this machine?
    disregard, I found it in the post processors.
    thanks,
    Davin
    Apr 2024
    Hi there, hope this post is still alive... Can you please tell me how to make it, I have this old ve-810 engraver and Im fighting with him how to make it work... please if is possible to explain what and how..
  1. Job Server / Vision Series 1 Controller
    By dsbihill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-22-2020, 08:50 PM
  2. aspire and Osai controller
    By ant818 in forum Aspire
    Last Post: 05-02-2016, 06:00 PM
  3. Need Post Processor file for Pronest 8 for ESAB Vision 21 controller
    By kautostar in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-30-2016, 12:28 PM
  4. Aspire from Vetric vs. Aspire from Alphacam
    By jooooooe in forum Aspire
    Last Post: 06-04-2015, 04:52 PM
