585,744 active members*
3,716 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > question about a table for a BenchTop PRO
    Nov 2006
    1036
    Just ordered a CNC-RP BenchTop PRO and hope to make a proper table for it before it arrives. I understand that the router has 4 leveling feet. In all the "in use" photos that I have seen, the router appears to be simply placed on a flat surface and friction between the feet and the table surface keeps the router in place. I'm concerned that the router might "wander" during use and wonder if it would be a good idea to contrain it in some way. I'm thinking of routed out circular depressions in small plates that could be placed under the feet and then screwed to the table. Anybody have thoughts, advice, or experience to share? TIA Don
    Jun 2013
    88
    Re: question about a table for a BenchTop PRO
    Hi - We haven't found cups/pockets in the table for the Benchtop PRO feet to be necessary in our experience, however it certainly couldn't hurt if you feel motivated to create small locating pockets. The machine is well balanced, fairly heavy. and smooth operating (go ballscrews!) - I suspect for all but the slickest surfaces you'll be fine either way.
    Enjoy your new machine!
    -Nathan
  1. Feeds and Speeds Question: Benchtop with 60k RPM Spindle
    By DRock in forum Benchtop Machines
    Last Post: 06-09-2016, 12:57 PM
  2. Replies: 2
    Last Post: 11-25-2014, 06:11 AM
  3. Table Top Question
    By DieselTwitch in forum DIY CNC Router Table Machines
    Last Post: 11-18-2012, 06:22 PM
  4. yet another vacuum table question....
    By boomerize in forum DIY CNC Router Table Machines
    Last Post: 08-18-2009, 06:16 PM
  5. Table care question??
    By Martin 007 in forum Uncategorised MetalWorking Machines
    Last Post: 09-12-2008, 06:06 PM
