585,573 active members*
3,600 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > MasterCAM Post - CNT Router w/ WinCNC Controller Help!!
    Sep 2006
    4
    I have a newer CNT Router that runs a WinCNC controller. I have an existing post that allows me to run MasterCam X but in some surface machining functions I'm getting large circles and arcs when I open it up on the controller and try to run it. It is fine when I verify it MasterCam prior posting. Does anyone have any suggeastions? Is there anyone that could help me fix this problem? I will pay for someones time.
    Mar 2007
    Cool Check your "D" offsets.
    Some post confuse "D" dia offset with The "H" height offset. If you have the "D" offsets turned on at the machine, and it has the same offset number as you height offset, the machine will try to compensate for the larger offset and make big arcs. To fix this problem, you can simply turn off the "D" compensation at the machine in you software, or edit your post. Open the post and look for a line of "Ds" with numbers beside it. Change these numbers to start with the fist number after the last tool that you have in your changer. ex, if the last tool is 10, then the first "D" offset should be 11. make sure that the offset banks in the controller for the new "D" offsets are all set to 0.000 or to the number you wish to compensate for, ex, -0.0010
    I hope that this helps.
    Perpetualdark
    May 2009
    5
    Hi. I have cnc router that runs on wincnc, i'm trying to find postprocessor for mastercam X3. Can you send it to me?
    Thanks in advance.
    May 2009
    28
    mastercam 9 post for wincnc router
    Does anyone have a post for MC 9 to wincnc?
    Mike
    Mike Westvang
    Dryad Bows Inc.
  1. mastercam post for practical cnc/wincnc
    By teacher in forum Post Processors for MC
    Last Post: 08-04-2008, 03:40 AM
  2. Post needed for WinCNC
    By behn in forum WinCnc
    Last Post: 02-19-2008, 09:26 PM
  3. BobCad with WinCNC controller 2.1
    By Scott V in forum BobCad-Cam
    Last Post: 01-17-2006, 08:23 PM
