585,974 active members*
4,458 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > driver A06B-6079-H105 terminating cinnector
    Mar 2008
    13
    Hi good day,
    I was removing the connectors of 20 pins of these drivers A06B-6079-H105 and i lost the terminating connector.
    I guess this take a few bridges, i can see the datasheet and conection of conectors JX1B a JX1A, the bridge is the connector JX1B.
    But i no find that pin jumper, Some of you have this information?
    regards
    Renato Masias
    Re: driver A06B-6079-H105 terminating cinnector
    Short pin 5 and 6
    Mar 2008
    13
    Thanks for the data.
    I have three connector air, and four connectors in the A06B, these are:
    JX5
    JX1A
    JX1B
    PWM11_JV1B,
    the connector terminating is connected a JX1B, the other a JV1B and the third i remenber seeing in the JX5, but according a manual these is in JX1A, then JX5 can be free?
    Also i try change the battery, these driver have a compartment af battery but is empty, I no can locate the battery, these is possible be in same encoder?
    regards
    Renato Masias
    Only the JX1B needs to be terminated. It satisfies the alarm loop. As far as the battery goes it is an option for the absolute encoder. Check parameter 1815 and if the APC bit (Bit 5 xx1xxxxx) is off then you don't need the battery.
  1. Replies: 0
    Last Post: 12-08-2013, 09:32 PM
  2. Alpha Series Servo Amplifier A06B-6079-H106
    By M.RISHIKESH in forum Fanuc
    Last Post: 11-25-2009, 04:12 AM
