Re: Interlock for VFD / Water Pump
I am getting confused, you said previously that the VFD would start when the G540 and Mach were off, now you say it is never left ON?
As I said, I do see a possible way if the VFD is ON and Mach and G540 is off, but you should never have this condition.
The VFD and all servo's/steppers should be disabled from operation until the system has booted up and is ready and enabled by Mach.
If Mach is not running, the power to the VFD should be OFF.
Al..
Albert E.
