585,759 active members*
4,030 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > need help for accurate deep hole drilling
Results 1 to 7 of 7
    Jan 2009
    117
    Post need help for accurate deep hole drilling
    I need to drill with the place very accurate. . I tried dril many ways but all methods were bit offset. so please advice me your suggestion. i have given some details about work part.
    Mildsteel
    Dimention: 31x16x110 mm
    Need to drill D13mm
    thanks.
    Asfar Sri Lanka.
    Attachment 335736
    Aug 2015
    108
    Re: need help for accurate deep hole drilling
    A straight flute won't walk as much if that is the issue you're having. Its also important that the drill is ground fairly accurately. A drill that cuts on one flute is going to walk.
    Attachment 335748
    Jan 2009
    117
    thanks for your details. what is the name of that tool. where can i buy that?
    Aug 2004
    780
    Picture tool is a reamer.You use it to finish last 0.2 mm of hole. Not to drill.
    You cannot drill it accurately with common basic tools.
    A drill press will walk- 0.1-0.2 mm or (much) more depending.
    A mill might get you a bit better - if you use good industrial drill bits.
    Carbide drills - much better. Expensive. 200-300$.
    13 Mm Solid Carbide Drill | MSCDirect.com
    You need to bore the hole to get it straight.
    Use a boring head on a mill. You will need to do from both ends, and locate accurately.
    Drill about 0.1 mm undersize.
    Finish with a reamer.
    Or, ..
    on a lathe, its possible to bore from both ends, and the bores will be very straight.
    Bore 12.9 mm, finish with reamer.
    On a lathe, you could drill to 12 mm first, and then bore to get it straight.
    Finish last 0.1 mm with reamer.
    When the workpiece rotates, the holes stay straight by nature.
    On a decent lathe, about 0.01 mm tir *and* accuracy is possible.
    About 0.02 mm is easy, with experience.
    0.01 mm size and straight is not easy, for such a long hole.
    0.01 mm true is hard.
    True means the location is accurate from both ends, and the hole is round (tir) and straight, throughout.
    There are 4 different concepts.
    Size, roundness, straightness, and location on both ends.
    HTH or Hope This Helps.
    Bore it in stages, first with very short boring bar, with only 1:3 overhang or less.
    3 x 13 mm = 39 mm deep.
    Then do the last 110/2x39=31 mm /2 = 15.5 mm with a longer bar.
    The first bore will be better, and will guide the reamer.
    It will work well, to 0.02 - 0.01 mm, on a 12x lathe.
    This is a difficult job, if both ends need to be accurately located.
    If only one end must be accurate in location, it is easy.
    Jan 2009
    117
    brother hanermo, thanks a lot for your information and spending your short time to comment for my post. really I got few points from your comment. Actually I don't care diameter of bit because i can manage with the male part. It must be very straight. that is very important for me. According to your advice tomorrow i will try to do from both end. what machine is better for this process? Radial drilling machine or lathe machine?///
    Jul 2014
    51
    If you have to make a lot of these holes then you should look at a gundrill setup.
    Ray Behner on the Practical machinist Forum had a posting about a gundrilling setup he made himself.
    Many machineshops have them and not for gundrilling , just for deephole drilling.
    Apr 2012
    90
    Hanermo,
    That is indeed a straight flute drill, NOT a reamer.
  1. Deep Hole drilling, really deep...
    By GM81 in forum Fadal
    Last Post: 11-25-2013, 10:57 PM
  2. Replies: 2
    Last Post: 09-03-2013, 11:25 PM
  3. Accurate Hole Layout & Drilling
    By vacpress in forum Mechanical Calculations/Engineering Design
    Last Post: 04-19-2006, 06:21 PM
