585,762 active members*
4,085 visitors online*
Results 1 to 6 of 6
    Dec 2007
    379
    Simple DIY bellow
    Anyone have ideas on what would be a good method or material to make simple bellows like these? I plan to just fold them andto have the bellows slide through 2 channels.
    Apr 2004
    5735
    Re: Simple DIY bellow
    Often bellows are made by laminating cloth and cardboard. For a bellows like that, you'd cut uniform strips of cardboard and glue them down on the cloth (oilcloth or rubberized cloth would provide more protection from fluids) with a little space between them to allow the folds room to form.
    Andrew Werby
    Website
    Dec 2007
    379
    that doesn't sound too bad at all. I think ill try that but with plastic instead of cardboard. Thanks
    Nov 2011
    205
    Do you want one like this one?
    Bellows, Chip Guard 1431 - LittleMachineShop.com
    Don
    Sep 2006
    6463
    Hi, a guy at our model club built the Quorn tool and cutter grinder and then went on to make some concertina bellows for the round steel rails either side of the work head.
    He first turned an aluminium bar about 40mm diam and cut some grooves on it but with rounded tops and bottoms.
    He sprayed the bar with furniture polish as a mould release......Silicon rubber sticks like sh!t to a blanket otherwise......... and then applied a coating of Silicon rubber sealer all round the bar......silicon sealer, the type you use to seal cracks from water entry.
    When this cured, approx. 24 hrs later, he peeled it off the bar and had a silicon rubber concertina bellows.
    He used the clear sealer and added some black clothing dye.
    This could also be used to make the flat concertina type bellows if you first make a flat mold to coat it on.
    The Silicon rubber can stand a fair amount of heat so hot chips might not do too much damage.
    Ian. .
    Nov 2008
    110
    Here: Bellows you can find instructions how to build DIY bellows - suggested materials and a program that generates
    folding template. These bellows cover 3 sides - no need for side channels.
    I build mine (light duty, very small machine) from polypropylene foil - scored lines with a scriber, folded, compressed in vice and used hot air gun to "fix" the form.
  1. sewn flat bellow
    By mactbellows in forum For Sale Only
    Last Post: 06-18-2015, 04:01 AM
  2. bellow covers
    Last Post: 06-12-2015, 02:05 AM
  3. supply of bellow covers
    By mactbellows in forum News Announcements
    Last Post: 05-25-2015, 08:38 AM
  4. Looking for replacement bellow hose
    By Unity in forum Waterjet General Topics
    Last Post: 01-01-2008, 07:40 AM
  5. Bellow Cover
    By Smackre in forum Linear and Rotary Motion
    Last Post: 06-25-2006, 03:04 AM
