Just posted on Ebay - priced to sell!
Watch that listing, price will drop over time, reverse auction style.
ESP-II Enhanced Power Controller 5 axis stepper driver/controller with plasma height control kit
This listing includes
  • ESP-II Enhanced Power Controller 5 axis stepper driver/controller box
  • Includes breaker and 15 amp 10 amp outlets.
  • 5x large dual shaft stepper motors, wired with plugs. 60hs100de06db
  • DCP-01 Digital Current Probe
  • DTHC - Torch Height Controller
  • Cables
This item was purchased new from CandCNC com a few years ago but never installed, it's time to sell it.
This was their top of the line 5 axis cnc + plasma controller system when it was purchased.
The product is still supported, and current software, drivers, and manuals available at
candcnc com / downloads
candcnc com / manuals
It runs on Mach3, and Screens and Profiles are included with the driver download.
Here is the description from the manual.
The ESPII Enhanced Smart Power controller is the third generation of power controllers from CandCNC. It has all of the advanced features of earlier models but with the ESPII, the product has become more modular, smaller and with more processor power. It still has all of the great features that have made the earlier series popular:
  • OVERVOLTAGE Protection for your expensive motor drives. Line surges or Back EMF that exceeds the safe limit for you drives is instantly shutdown and clamped. Dynamic LOAD DUMP on shutdown drains the DC buss in seconds.
  • OVERLOAD Protection. Wheather it!s from an accidental short or serious malfunction, the supply will shutdown on heavy current demands that exceed the supply!s limit. ELECTRONIC FUSING is 100 times faster than conventional fusing
  • SOFTSTART circuit prevents AC startup surges that can blow breakers and cause component failure. Startup over 3 seconds keeps unrush current to below normal running (loaded) current.
  • TEMPERATURE Monitoring and shutdown. If your electronics are running two hot it!s hard on them and makes them subject to premature failure. Internal probes sense the temperature and will pick up a clogged filter or defective fan.
  • ON SCREEN Readout of all parameters including Voltage, Amps and Temperature. Just like commercial controllers costing thousands of dollars more you have the information right on the operators screen.
  • FEATHER TOUCH ON - OFF buttons for MOTOR DC.
  • OPERATION ON any power from 120V 50/60 HZ to 240V 50/60Hz.
  • PLUG TOGETHER modules are easier to troubleshoot and easier to replace in the field. All CandCNC products use the same basic modules. Modules can be changed in minutes.
  • FRONT PANEL STATUS lights let you know what is going on. From normal operation to a fault condition the panel will give you the status instantly. If a drive faults know which one.
  • HIGH SPEED PROCESSOR based Front Panel control
  • INSTANT FAULT SHUTDOWN
Keep Checking Back - price may change.
Fast shipping! I ship the same day you pay.
USPS Shipping to verified paypal addresses in US only.
PM any questions, or take 10% off if you want to skip ebay.
ESP II CNC Control w 5 Nema23 Steppers DTHC Plasma Control Works Whypertherm | eBay
