585,877 active members*
3,365 visitors online*
    Sep 2016
    Rich Auto controller issues
    Hello everyone,
    I have a RchAuto controller that upon power up stops loading at 80%. Can anybody help with what the problem may be? I have tried a new cable and that doesn't seem to be a problem. Also tried powering up several time. That didn't work either.
    Thank you for all suggestions in advance.
    Jul 2013
    Re: Rich Auto controller issues
    It is probably encountering a corrupt line of code. I have a Richauto A11E and it suddenly started only getting to 46% when loading and then hanging.... A firmware update fixed that, but you will need to know all the parameters for your machine because you will be spending some time in "menu" setting them. You can get a complete list from you manufacturer....(mine was Laguna). You have to set all the settings in machine setup like the pulse equivalent, etc.(different for every brand of cnc)
    Hope this helps. Make sure you talk to your manufacturer before you do anything though....
  1. Z Axis auto zero plate wiring on usb motion controller
    By phongshader in forum Chinese Machines
    Last Post: 11-10-2017, 02:01 AM
  2. Replies: 25
    Last Post: 04-24-2015, 03:56 AM
  3. Taig controller off, Auto zero still detected
    By TaigCNCer in forum Community Club House
    Last Post: 07-12-2013, 06:52 PM
  4. Replies: 0
    Last Post: 06-08-2011, 02:36 PM
  5. Auto-Off a problem with the Xbox 360-Wireless-Controller?
    By Spartan117 in forum Mach Wizards, Macros, & Addons
    Last Post: 08-07-2009, 07:43 PM
