I'm building a 5x10 machine based off the CNCRouterparts Pro series using an 2" square tube steel frame and NEMA34 motors. dual for X axis. I'm running the ESS smoothstepper from a WinXP machine running latest rev of Mach4 through a C11 BOB. I'm able to sync up without any problem, Y axis works great in jog mode, z axis needs some minor tuning, but I'm beyond baffled as to how to get the dual X motors not to fight each other. I have a single limit switch for each axis wired up now and CANNOT get the two X motors not to fight each other. Xr (right side of machine) is wired to X axis, XL is connected to A. No matter what I change, they insist on turning (the same, but since they're mounted directly to rack and pinion 180 degrees offset...) opposite directions. Ger21 made a comment a while back how he answered that question 3x in one day, and I have scoured the internet for two days trying to figure out a possible solution. I have checked the reverse box in Mach motor config, I've inverted the limit switch direction, etc etc, but nothing makes any sense. Motors are set up as X=0, Y=1, Z=2, A=3, with Motor 3 being slaved to X. I can provide screenshots, photos, and anything else, but I'm lost on the initial setup of the homing and limits. I've referenced the pdfs for the ethernetsmoothstepper setup and troubleshooting guide, and just about every page on warp9td.com.
What am I doing wrong?
thanks!
