ok I have tried in aspire and created rounding tool path both raster and rounding around the cylinder it does try to cut the file but does not seem to cut in the correct spot is it a post problem or a step problem on the rotary axis I'm trying to find a simple g-code using the A axis to turn a pc of wood 5.5" square 18" long z is the center of the work piece I want to turn it down to a 5" cylinder using a .5" end mill so I can rule out the post processor problem or the rotary not set up correctly hope someone can help
Steve
