Motor grader is used very often in the road building and leveling. It is troublesome when the machine breaks down during the working process under a tight working schedule. In case of emergency, construction equipment daily maintenance is very important to keep the machine in a good condition all the time. The followings are some guidelines about road machinery daily maintenance.
Engine is the heart of the construction equipment, the machine will stop working if the “heart” goes wrong, so more attentions should be paid to the engine of the Motor grader. Before starting the engine, we should check the fuel level to make sure the machine can operate normally. What is should be noticed is that the fuel should not be filled too full since fire will be caused if the fuel overflows under high temperature. Check the fuel pipe and fuel tank to avoid any leakage. And the remaining water and other sediment should be discharged every day to keep the fuel tank clean and purified. The coolant should be added enough to keep the machine work normally. The radiator should be checked regularly to keep the machine cool and the damaged radiator should be changed immediately to keep the machine operate smoothly.
If only you master the above maintenance guidelines, your road grader will operate in high efficiency and create more profits for you.
