585,599 active members*
3,648 visitors online*
Results 1 to 11 of 11
    cnc with a heated spindle
    Anyone knowledgeable to create a spindle pin/ collet with heat180- 300+ degrees...... temp controlleable
    Apr 2004
    5731
    Re: cnc with a heated spindle
    Why do you want to do that? Usually, we try to keep our spindles and tooling cool.
    Andrew Werby
    Website
    Feb 2009
    6028
    Since 145 deg is about max for spindle bearing grease before it causes issues, don't think this is a good idea.
    Sent from my A3-A20FHD using Tapatalk
    Nov 2012
    1267
    Well, you have to either use bearings that could withstand high temperatures (ceramic?), or insulate the hot tool from the rest of the spindle somehow.
    I'm curious, what is the application for a heated rotary tool?
    Quote Originally Posted by awerby View Post
    Thanks Bro for the early reply......
    I assumed that would bring some problems but what if the actual colett and drive attached are tendem to the actual motor via belting(off-center)! ..i'm attaching a pic.
    Thanks citizen...that got me a whole lot thinking of ceramic bearings....Great !! that should answer UNDERTIRE's reply.......Application.?......still on experimentals11...heres a pic of the spindle especially done off center for the purpose
    Apr 2004
    5731
    If you get the spindle seriously hot, what keeps that rubber belt from melting?
    Andrew Werby
    Website
    Feb 2009
    6028
    Ceramic bearings still need lubrication....
    Nov 2012
    1267
    Quote Originally Posted by underthetire View Post
    According to Boca Bearing Company, full ceramic bearings can be run dry.
    Feb 2009
    6028
    Well, that would be a first I've seen dry ceramic bearings, but maybe worth a shot. Air bearing spindle might be a good option.
    WOW DIDNT EXPECT THAT COMING ..WHERE DO I GET THEM .......ANYTHING THAT WORKS IS WORTH TRYING ....MAYBE EVEN A COMBINATION !!
  1. Replies: 2
    Last Post: 04-28-2015, 08:51 PM
  2. Heated Bed Stuff
    By SPEEDRE in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-28-2014, 08:20 AM
  3. What is the purpose of a heated bed?
    By MjWhit in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-28-2014, 08:18 AM
  4. Wire a safe PID for a Heated 3d Printed Bed
    By SPEEDRE in forum CNC Machine Related Electronics
    Last Post: 01-10-2014, 01:08 AM
  5. Stepper slow and gets heated
    By fanwary in forum Stepper Motors / Drives
    Last Post: 06-27-2013, 11:47 AM
