585,962 active members*
3,640 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Really weird improper toolpath following.. even seems to show in mach3!
    Jan 2016
    4
    So i cut some parts, quickly, and the inside of the letter "B" didn't properly follow the contour. The weird part is that it was consistent to the point that it seemed like it was designed that way.
    I went back to aspire to check it out, and everything looks normal, and the aspire simulation looks great.
    When I pull it into mach3 though, look at the path it takes. One weird thing is that if I run through the toolpath slowly, it doesn't do this. Notice when I run in reverse (second half of this short video), the same problem occurs but in a different spot:
    2016-10-19_1251 - Volte6's library
    Any idea why this is occuring? It shows up in the part as well (attached):
    Note - you can see the proper toolpath right next to the flaw, because later I did a pass with a v-bit to bevel the edge without issue.
    EDIT: Here is another short video of it running at a slow speed - no strange behavior! 2016-10-19_1305 - Volte6's library
    Feb 2004
    1086
    Re: Really weird improper toolpath following.. even seems to show in mach3!
    Hi Dylan,
    This is almost certainly an issue caused by the CV settings in Mach3, which basically tell the machine how much it's allowed to "blend" vector moves to achieve fluid motion. It's an old post, but here is some good information about CV, why it exists, and how to tweak it:
    New CV features
    For what you are doing, I would set the CV distance tolerance lower, set the "stop CV on angles" to a lower number, or both (this is under the config->general config menu). Since Mach calculates the toolpaths upon loading your G-code, you should be able to see the effects by re-loading your G-code with the new settings.
    If you need additional support, feel free to give us a call and we can talk through it.
    Best regards,
    Ahren
    CNCRouterParts
    Jan 2016
    4
    Thanks ahren, AAA support as usual!
    Jun 2010
    4256
    It is possible that the motor speed and acceleration parameter setting could also be improved. This would need some experiment.
    Cheers
    Roger
    Yes, acceleration and CV settings are very much related to each other.
  1. Weird Mach3 issue
    By RhinoRacing in forum Controller & Computer Solutions
    Last Post: 08-12-2016, 06:57 PM
  2. What does the toolpath simulator really show?
    By BrianSP in forum Dolphin CAD/CAM
    Last Post: 09-16-2010, 02:10 PM
  3. Weird problem with abbreviated toolpath
    By wpflum in forum Machines running Mach Software
    Last Post: 03-15-2010, 01:39 PM
  4. Mach3 weird behaviour
    By mrpeja in forum Mach Software (ArtSoft software)
    Last Post: 09-23-2009, 05:48 PM
  5. SX3... improper Mach3 pinout ?? no steppping
    By krazatchu in forum Syil Products
    Last Post: 02-19-2008, 12:21 PM
