585,942 active members*
3,421 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Offering help with Emmegi CamPlus, Drill, and Shape
Page 2 of 2 12
Results 21 to 36 of 36
  1. #21
    Aug 2020
    Re: Offering help with Emmegi CamPlus, Drill, and Shape
    problem loading DXF files into Camplus. any better formats to load profiles
    cheers
  2. #22
    Aug 2020
    I am having a problem importing DXF files into Camplus. i am exporting out of Fusion360 so i can export a large number of file format but am stuck. any help would be great.
  3. #23
    Sep 2020
    I currently have a Emmegi M3 running CamPlus. I am looking for a program to run hobby projects and SHAPE has been mentioned a few times.
    -Where can I download the SHAPE Program from?
    -Will it interfere with CamPlus?
  4. #24
    Nov 2020
    I'm using CAMplus and every time I try to save an LDT, I get an error message "Too long LDT name". The problem is, I see several other LDT name that are much longer than what I'm trying to use. So obviously other users can save longer names. I've asked the other users in my office about it but they all seem to be clueless as to how to fix the problem. I've looked through the "Options..." but nothing seemed obvious. Any Ideas?
  5. #25
    Aug 2021
    Hi Steven
    We work with an Emmegi Comet R4.
    This is a 5 axis machine tool.
    I create my models from Autodesk Inventor and export each profile from Inventor to a step file.
    Now I work with a borrowed dongle with Driver-Cad on it.
    This is an add-on to Camplus 5.0 that allows you to load step files.
    You then have a recognition tool that recognizes all edits and the profile and assigns the tools.
    In most cases it goes well, but I don't get the countersink recognized.
    In the tools we have copied the config from Drill and the countersink is recognized.
    However, I get the message: No listed Countersink.
    How do I get the countersink to work so that it is recognized.
  6. #26
    Aug 2021
    Hi @jlucas
    Did you place the dxf in the right location.
    I have to put my dxf's under Cam-DXF so the Camplus can find and use the wright dxf.
  7. #27
    Aug 2021
    Hi, just started to use CamPLUS. I would like to know what's the difference between profiling and emptying. Also, is possible to create a rectangle without rounded corners? If yes, have to use a special tool?
    Thank you in advance!
  8. #28
    Nov 2021
    Quote Originally Posted by Imran1234 View Post
    Hi
    Let me know if you need help, CamPlus, Shape, BidiCam, Job and Drill and machine setup for special profiles.
    Also, CadLink and CAM3D. I have done a lot of work on Emmegis and Mecals.
    Can you help me please i am new one here i need help about Camplus
  9. #29
    Nov 2021
    Hello Guys i need help
    I using Camplus i has two tool 8 endmill and 6 endmill
    I doing a operation first one start x left side
    Another operation begining x right side how can i make start two both them x left or x right?
  10. #30
    Apr 2010
    24
    I'm considering purchasing a Phantomatic T3 Star for machining aircraft extrusions. You'd think they would try harder to sell me on the software. I just want to know (without taking their word for it) between CamPlus and Shape, can I import a 3D DXF file and create a program for the part? Nothing too complex, but enough that I don't want to re-create everything from scratch. Compound angles on the ends, angled slots, hole locations. TIA
  11. #31
    Jan 2022
    Quote Originally Posted by Machinist21 View Post
    Hi Machinist 21
    Profiling will do miling on the tracing or contour while emptying will mill all the enclosed area.
    Regarding the corners there is no option you have to us3 the smallest possible bit.
  12. #32
    Apr 2010
    24
    I decided to buy a custom built machine from a local builder that reads G-code so we can use our CAM software to generate programs from our Inventor files without the limitations of the Emmegi software.
  13. #33
    Apr 2022
    What is a .LAV file?
  14. #34
    May 2023
    I'm new to CAMPLUS and i'm trying to figure it out, it's different than others CAM software.
    I have some questions and maybe someone can answaer me:
    1. How to do an operation and put it on any profiles? (when I load from an other LDT sometimes is compatible sometimes isn't)
    2. When it works are 2 options:
    a. The program ask me: Merge selected LDT with current LDT? If I press YES it works, but the selected LDT is it modified in some way? on current LDT it works but the X,W,H in operations are not the same with the coordinates system.
    b. The program ask me: The LDT's are NOT compatible do you what to proceed? It works but, are the profiles modified in some way?
    3. In the HDRILL on Tools, in the Tool modifier tab, How the remover speed is calculated?
    The feeds & speeds in the catalogue are in mm/min or mm/tooth.
    In the HDRILL manual writes hundredts/rev and on the machine, in HDRILL, it is 0.01/rev.
    How to convert mm/min to hundredts/rev ?
    4. The parametric values list doesn't work, I followed the steps in the manual. How it's done correctly?
    Thank you!
  15. #35
    The dxf file needs to be in broken lines (not polyline)
  16. #36
    Aug 2023
    Question Re: Offering help with Emmegi CamPlus, Drill, and Shape
    Hi Guys
    Could anyone knows how to open JOB files (*.jlt) by CAMplus or anyway to change it to CAMplus file (*.ldt)
  17. #37
    Hi, do you still offer programming support? We have 2 emeggi aluminium profiling machines and need support with programming
Page 2 of 2 12
  1. Camplus on Emmegi
    By Session in forum Uncategorised CAM Discussion
    Last Post: 02-14-2024, 12:15 PM
  2. Help on Emmegi Diamant Equipment Using Camplus
    By scott4tg in forum Uncategorised CAM Discussion
    Last Post: 03-03-2022, 02:37 AM
  3. Ordered LDT in CAMPLUS
    By jarand in forum Uncategorised CAM Discussion
    Last Post: 10-24-2016, 01:31 PM
  4. Any one 4 help ..plz ...emmegi cnc
    By Muradrabaia in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2013, 06:28 PM
