585,760 active members*
3,849 visitors online*
Page 2 of 7 1234
Results 21 to 40 of 133
  1. #21
    Jul 2016
    19
    Quote Originally Posted by koolkleptokidd View Post
    Its 120v
    I tried the d020 and d040 setting and it does the same thing.
  2. #22
    15362
    Re: 6040 cnc PRT-E1500W vfd settings.
    So the trim pot makes no difference when you turn it, we will try some different setting that control this D031=5
    Do you have the VFD in the right mode for Running you may have to scroll to select this
    Mactec54
  3. #23
    I bought a 3020 with 800W spindle last week and thanks to this thread I figured out how to get it working.
    The manual states only to change D032 to 1, which did not work when trying to control it from Mach3, the motor simply does not start even if the display shows the right values and I do hear a relay click in the controller.
    Setting D032 back to 0 solved the situation for me! I have not had to change any of the other values other than D001 to 1 to allow changes to be made.
    Anyway, just wanted to thank you for the info and figured I'd post this for future reference, because I'm sure everyone else going by the manual will run into the same problem and will most likely end up on Google and hopefully finding this thread
  4. #24
    15362
    Quote Originally Posted by snq View Post
    Could you look at all your parameters well up to 40, and write them down, as koolkleptokidd is still not running, his spindle turns on, but will not get up to speed, it could be just one parameter that is not set correct, and from what you have set, we may be able to see what is wrong
    Mactec54
  5. #25
    Sorry for the late reply, I didn't get a notification.
    Since I posted I found a little bug with my previous statement. It would control the RPM fine, but it would not turn on by itself unless I had turned it on manually on the controller. Discovered that the next time I used it... It would turn off simply by setting the rpm to 0.. Which was at least better than before when it would not be controlled by Mach3 at all
    With a little help from the supplier I've now got everything sorted and it both turns on and controls rpm from Mach3. Everything is working as intended, as far as I can tell.
    D032 is back to 1, and I had to change one setting in Mach3.
    Here are my current settings that work for me. I should add that my VFD is a PRT-E750, not a 1500.
    Code:
    0	50.00
    1	0
    2	00.00
    3	00.00
    4	220.0
    5	00.00
    6	110.0
    7	00.50
    8	001.7
    9	00.00
    10	00.00
    11	10.00
    12	10.00
    13	10.00
    14	10.00
    15	10.00
    16	10.00
    17	10.00
    18	10.00
    19	01.00
    20	06.00
    21	50.00
    22	0
    23	0000
    24	0000
    25	0000
    26	0000
    27	0000
    28	0000
    29	0000
    30	0000
    31	1
    32	1
    33	0
    34	0
    35	0
    36	0
    37	004
    38	001
    39	000
    40	100.0
    I've also attached screenshots of my Mach3 settings.
    Hope this helps!
  6. #26
    15362
    Code:
    0	50.00
    1	0
    2	00.00
    3	00.00
    4	220.0
    5	00.00
    6	110.0
    7	00.50
    8	001.7
    9	00.00
    10	00.00
    11	10.00
    12	10.00
    13	10.00
    14	10.00
    15	10.00
    16	10.00
    17	10.00
    18	10.00
    19	01.00
    20	06.00
    21	50.00
    22	0
    23	0000
    24	0000
    25	0000
    26	0000
    27	0000
    28	0000
    29	0000
    30	0000
    31	1
    32	1
    33	0
    34	0
    35	0
    36	0
    37	004
    38	001
    39	000
    40	100.0
    Hope this helps!
    They are the strangest VFD settings I have ever seen, to run a spindle like this, can you take a photo of your spindle, and do you have the full RPM range 6,000 to 24,000 RPM
    Mactec54
  7. #27
    These are the settings it came with, except for D032. As far as I can tell it has the full range. I will add that it does take a while to get up to speed, I'd say close to 10 seconds to spin up to 20k from 0.
    The spindle is an 800W 65 mm watercooled one. Here's the ebay listing that has all the specs, it looks exactly as on the pictures.
    DE! CNC ROUTER GRAVIERMASCHINE 4 AXIS 3020T ENGRAVER ENGRAVING 4 ACHSEN GREAT in | eBay
  8. #28
    15362
    Great !!! it takes 10s to get up to speed, because it is set at 10s , Parameter D011 you can adjust this, it will fault out though, if you go too low with this setting
    Does it get to the full speed of 24,000 RPM
    Mactec54
  9. #29
    Feb 2017
    5
    Does anybody have a copy of the PRT-750 vfd manual? If so is there anty chance you can forward me a copy as I'm having a hell of a time setting up my 3040 which has this controller & the 800w water cooled spindle motor.
  10. #30
    15362
    Quote Originally Posted by -Bucks- View Post
    You should follow what snq has posted for his setup that should get you going, I can not upload the manual, PM me your email and I will send it to you
    Mactec54
  11. #31
    Feb 2017
    5
    Ok I'll have a look at that, I'll pm you my email address now THANKS
  12. #32
    Feb 2017
    5
    We are having the same issue snq! What setting in Mach3 did you change to overcome the problem with the D032?
  13. #33
    Mar 2017
    4
    Any new news on this? I have the same VFD and have entered all of the numbers listed and all I get now is flashing digits "00.0" on the VFD screen. It does not respond to manual or Mach3
  14. #34
    Feb 2017
    5
    Try pressing the run button on the vfd, the 000s should stop flashing, I've got my D032 pin set to 0 & have to press the run button every time I turn the controller on, I don't know if this is normal but at least I'm up & running!
    Hope this helps
  15. #35
    Mar 2017
    4
    Yeah, I tried that. I think I am close, it will stop flashing when I click the spindle control in Mach, by it will not turn either from Mach or by hand . I just dont know which setting is off. I tried matching SNQ setting that were posted with no luck as of yet. There were a couple of the setting that I could not get to match his, it would not let me zero them out. I dont remember which ones.
  16. #36
    15362
    Quote Originally Posted by Twofinger View Post
    Check that D001=1 if at 0 then it will not let you change the Parameters
    Mactec54
  17. #37
    Nov 2016
    6
    In attachment. We hope this will help.
    Best regards.
    KH-5030 and a lot of good will
  18. #38
    Mar 2017
    4
    I really think I need the US settings for the VFD, I dont think I have mine right.
  19. #39
    Mar 2017
    4
    I found out how to get it set back to factory settings. Now I just need to get all of the frequencies set. I am still learning about the whole VFD concept.
  20. #40
    Dec 2016
    30
    How do you get it back to factory settings? i still cant get mach3 to control mine. if i turn it on in mach it ramps to full speed, if i try to change the speed AT ALL it dtops it to 1/4th speed. Cant figure it out. Also im getting a pwm limit hit error.
Page 2 of 7 1234
  1. 6040 CNC VFD settings?
    By RoddQLD in forum News Announcements
    Last Post: 05-18-2019, 01:00 AM
  2. New 6040 CNC machine. Spindle controller settings.
    By RoddQLD in forum Australia, New Zealand Club House
    Last Post: 05-29-2018, 08:29 AM
  3. 6040 cnc PRT-E1500W vfd problem
    By koolkleptokidd in forum Spindles / VFD
    Last Post: 03-18-2018, 11:52 PM
  4. yoocnc 6040 s80 settings
    By RABBIDUS in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2013, 08:32 PM
