584,812 active members*
5,443 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What Controller for Step-Syn Motors?
Results 1 to 7 of 7
    Jan 2009
    19
    I built a CNC machine 6 years ago and purchased the cheapest step motors I could find.
    It worked but the travel was 11" per MINUTE!
    It's time to build again and I have 4 Step-Syn motors out of an old embroidery machine.
    They are 103-8573-5612 / 1.5 Amp / .72 degree per step / 10 wire motors.
    Question:
    What controller will drive these things?
    Do I need a power supply?
    I have no clue and can't find anything on these motors.
    Thanks.
    Attachment 337452
    May 2005
    1397
    Re: What Controller for Step-Syn Motors?
    Wait... 10 wires? Really?
    If you have an ohm meter, can you check out the leads and see which wires are connected via a coil to which other wires? I'm curious to know how many coils are in the thing.
    As to your new machine, I would really suggest finding some more standard motors. This page may help:
    Good Unipolar Stepper Motors
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Apr 2004
    733
    It's a 5 phase stepper motor if it has 10 wires. You can find old Vexta 5 phase stepper drivers on eBay sometimes.
    Jan 2009
    19
    Quote Originally Posted by jfong View Post
    I'm so sorry for having to ask the following question.
    Would each motor require it's own driver?
    Apr 2004
    733
    Quote Originally Posted by kbeard View Post
    Yes every motor requires its own driver.
    Jan 2009
    19
    Wow. I think I'll reset and just go with a prepackaged new set.
    Too much to worry about trying to get old motors to work with unknown controllers.
    Sep 2019
    KBEARD, you still have those Step-Syn (103-8573-5612) SANYO DENKI STEPPER MOTORS w
    Question:
    Thanks.
    Attachment 337452
    KBEARD, you still have those Step-Syn (103-8573-5612) SANYO DENKI STEPPER MOTORS,
    with you ???
  1. 3 Axis, 4 motors - any step by step config?
    By nicubila in forum LinuxCNC (formerly EMC2)
    Last Post: 12-30-2012, 12:27 PM
  2. step by step instruction for building controller
    By avengine in forum Community Club House
    Last Post: 04-21-2006, 01:24 PM
  3. Help to find controller card & step motors...
    By Mikael in forum CNC Wire Foam Cutter Machines
    Last Post: 09-11-2004, 11:05 PM
  4. Wish controller and step motors should I use....
    By Mikael in forum CNC Machine Related Electronics
    Last Post: 06-30-2004, 10:35 PM
  5. Wish controller and step motors should I use....
    By Mikael in forum Community Club House
    Last Post: 06-29-2004, 11:46 AM
