584,830 active members*
5,692 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Drive Hitachi Seiki VK45 II
    Oct 2016
    14
    Good morning,
    I have a problem with the servo driver of my VK45. The servo driver is by NEC 193-230072.
    The problem is that the previous owner has burned a mosfet, and replaced it with a compatible and not with an equal.
    Now unfortunately do not remember the original mosfets code.
    I ask if anyone has a similar car if you can not read the letters written on the component.
    I tried the online drive sheet date, but have not found anything
    So the mill work some days, and then i have to change the mosfet again (I think because the features are slightly different)
    Thank you
    Dec 2009
    539
    Re: Drive Hitachi Seiki VK45 II
    Hello,
    what you need is
    NEC K831 - check for the datasheet here and find one that is compatible if need be
    2SK831 Datasheet(PDF) - NEC
    John
    Quote Originally Posted by firstreal View Post
    Good morning,
    Thank you
    Oct 2016
    14
    Thank you so much John
    Jan 2021
    13
    HI
    *I have a hitachi seiki vk45 vmc Ladder corrupted*and no backup and no softwarecan you please*help me([email protected])
  1. Hitachi Seiki VK45 with undeletable program
    By The MACHINIST in forum Hitachi Seikis
    Last Post: 08-11-2023, 07:36 AM
  2. Hitachi Seiki vk45
    By davesnd in forum Mori Seiki Mills
    Last Post: 12-02-2010, 05:47 PM
  3. hitachi Seiki VK45 tool changer stuck
    By Dancy in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2007, 02:06 PM
  4. hitachi Seiki VK45 with Seicos II
    By Dancy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2007, 09:26 PM
  5. hitachi Seiki VK45 with Seicos II
    Last Post: 12-11-2007, 09:16 PM
