586,011 active members*
5,002 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Problem with Hurco km3p startup
    Dec 2009
    17
    I have just purchased a used Hurco km3p CNC knee mill .I got struck on start page showing machine specifications like X axis travel
    Y axis travel
    Z axis travel
    Spindle speed
    And only one soft switch exit
    Which when pressed doesn't goes to next page.
    Jun 2008
    1104
    Re: Problem with Hurco km3p startup
    Press exit then 'enter' 999 'enter'
    Dec 2009
    17
    Quote Originally Posted by bloke View Post
    Thanks but machine does not jog in manual mode and if spindle is started it stops automatically after a minute, further machine does not do warm-up procedure. This machine is not in operation for a long time ,so does it be having memory board battery lost.In this case will machine loose it's parameters, if so where will I get those.Please guide.
    Shailesh Sheorey
    I have hurco km3p ultimax controller after a long time in store I tried to start the machine but 1 page got struck than I use enter 999 enter as told by you some time back . got on manual page but while resetting servos x asis motor started to oscillate and start button still flashing . Earlier while pressing start am air valve activating noise use to come which now does not rest all things like flood , mist , buttons wiork and appropriate relay operates. can you help in this . memory board originally does not have batteries on it but it has battery pockets there on board, .
  1. Hurco KM3P
    By ivanfed in forum HURCO
    Last Post: 11-15-2011, 09:25 AM
  2. KM3P startup problems
    By sdroke in forum HURCO
    Last Post: 07-25-2009, 12:59 PM
  3. KM3P problem startup
    By jimc80 in forum HURCO
    Last Post: 07-09-2009, 07:38 PM
  4. Hurco KM3P
    Last Post: 04-20-2009, 10:48 AM
  5. Hurco BMC 20 startup problem
    By tirebiter in forum DNC Problems and Solutions
    Last Post: 11-08-2006, 11:50 PM
