Re: Huanyang VFD Macro/ Plugin
Originally Posted by
Dan911
Hey Peter,
Yes that's disappointing, unfortunately I don't know what more I can do on plugin end. Briefly... the plugin uses the same variable sent to Sact for calculation of HZ, I been using all day and working flawless. You need to check on your end for possible noise related issues that can be the cause. I see you have your VFD right next to your controllers, I couldn't see if you were using a shielded cable from RS-485 and spindle.
I also see you have a speed control knob, have you tried disabling it? I think there's a jumper for this along with additional PD settings in VFD software, I read of many having trouble with this control. I'm certainly going to double check everything on plugin end.
Dan
I really, really appreciate all the help you have given in trying to sort this out for me and others.
It makes sense that if I am the only one experiencing the speed issue then it is something at my end.
I have been in the fault finding game too long to blame or rule out any particular part as ok until I have tested and proved it.
I am very mindful through out all my testing of the noise issue given where the VFD is located, though realistically the cable will be run to it no matter where I put the thing.
The cable from the VFD to the RS485 is a balanced shielded cable with the shield connected to earthed.
To make sure the problem wasn't noise from the VFD I did the tests with the spindle unplugged and just monitored the VFD display to make sure the speed was changing.
It still fails for me though and using an audio probe I can hear the data being sent from the RS485 to the VFD so I'm sure the plugin is solid.
That is why I was thinking it may be an RS485 adapter issue. Maybe its output is dodgy.
I have already ordered a unit with the same chipset that Gerry and Jack are using to see if it produces different results and will post my findings.
It could also be an issue with my VFD but I don't see myself getting a spare one at this time.
The Jumper is in the VI position on my VFD and I had setup Analogue speed control just before moving onto RS485 to see how it went.
I will also go back to Mach3 and give it a damn good thrashing to see if I can fault it as well.
Once again thank you for all the hard work you have put into this.
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
