just had a lns barfeeder installed on a okuma cadet.So many problems have happened since.My main question is why can i not run a program when cycle start is pushed....i can only run in single block.Even though the single block is off.
Is the LINK mode switched ON or OFF? I think this may have something todo with the run mode.
I take it you have been in contact with your local Okuma Rep regarding this problem also and had no luck?!?
Regards
Brian.
