585,712 active members*
4,006 visitors online*
Thread: Calibration
    May 2014
    Unhappy Calibration
    Please help me rdworks calibration x/y
    machine=1800x1300mm
    Oct 2016
    14
    Re: Calibration
    If these are 2 runs of the same pattern, then a repeat-ability problem exists. I would check for loose belts, that is to say loose enough for the belt to slip over the pulley teeth. It is also possible for the belt to be too tight, but it is unlikely. Also, ensure that the head travels smoothly, if it binds at all during travel you will loose steps. If you have just received the machine, go over it looking for loose bolts, nuts, & screws. When we received our machine we found many that had come loose during shipping.
    I am sure that some other can chime in with other suggestions.
  1. Calibration Help
    By Jamesdee in forum Stepper Motors / Drives
    Last Post: 09-06-2015, 04:42 PM
  2. X Y Calibration?
    By Robofarmer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-30-2015, 02:45 PM
  3. Calibration
    By slamman in forum DIY CNC Router Table Machines
    Last Post: 03-13-2012, 08:08 PM
  4. Need calibration help
    By JasonCcnc in forum DIY CNC Router Table Machines
    Last Post: 07-25-2011, 03:11 AM
  5. Calibration
    By metalfixer in forum Waterjet General Topics
    Last Post: 12-22-2008, 11:27 AM
