In the interest of documenting things that trip me up...
I was planning to do some engraving with my spring loaded drag engraver. Generated the code using Cut2Ddesk (it's very fast with engraving g code). Because it was the drag engraver, I just set the cutter speed to zero. Hadn't used the drag with PP before. Load program. No alerts, no status messages. Runs fine, up to completing the pre position (G0) line. Program stops with the cycle start button blinking. Will not continue past that line despite clicking on cycle start. Relevant code fragment:
N290T7M06
N300 (Tool: Engraving Diamond Drag)
N310G00G43Z0.8000H7
N320(Mist coolant ON)
N330M08
N340S0M03
N350(Toolpath:- Profile 1)
N360()
N370G94
N380X0.0000Y0.0000F5.0
N390G00X1.0000Y1.0000Z0.2000
(stops executing at this point with cycle start light blinking. Won't continue.)
N400G1X1.0000Y1.0000Z-0.0170F5.0
Eventually the light dawns... Pathpilot is waiting for some ready signal. In this case, perhaps waiting for the speed to hit the target RPM? Sure enough, delete the speed and spindle on commands, and now it runs fine.
Didn't track it further than that, I just deleted the line and got on with it.
This seems like rational behavior from PathPilot. It got a couple perfectly OK commands, and it's waiting for the condition to be met. So, no bug report to Tormach.
But...if your g-code post always generates a speed word and spindle command, you might see some puzzling behavior when you set speed to zero and then start the spindle, without any grumbling on the status display from PP.
