i been trying to get my cnc router running dependably for longer than id like to talk about with a C62 and a M44B from cnc4pc. told it should work fine. Then told to solder on a resistor on the m44b because there was a issue. then i was told they would send a new board. Then i was told there is a software issue. so i finally got a new version sent to me that suppose to come out in a few weeks and i still can not get it to run reliably. I had it running for a short time now it wont even reset. Ext.e-stop triggered is the fault that comes up randomly. The jumper is set to not use a remote pendant and none is installed either. dont want to bash anyone online. just want to fix this. if anyone has had similar results or has info to share that would be great. also if you know of a proven set up that uses uccnc software by Ethernet let me know as i may be moving on from this hardware soon. i have had zero luck. i will also contact cncdrive and get there thoughts also .thank you K
