I have problems cutting acrylic - melting and wrong chip formation. Used acrylic is extruded acrylic (Evonik brand). Used cutter is CMT 188.050.51 (5 mm (0.2") single flute solid carbide upcut bit for plastic and aluminium, not listed in CMT catalog any more).
Based on materials I read I started on the bottom of chipload range I hoped that should work but the results are bad. Pictures description:
The first picture - below the black line, actual results of slotting. Above the black line - slots with chips removed. Individual slots:
A - 12.000 RPM, depth of cut 2.5 mm (0.1", half the diameter), chipload 0.1 mm (0.0039"), feed rate 1.200 mm/min (47 IPM)
B - chipload 0.11 mm (0.0043"), feed rate 1.320 mm/min (52 IPM)
C - chipload 0.12 mm (0.0047"), feed rate 1.440 mm/min (57 IPM)
D - chipload 0.13 mm (0.0051"), feed rate 1.560 mm/min (61 IPM)
E - chipload 0.14 mm (0.0055"), feed rate 1.680 mm/min (66 IPM)
F - chipload 0.15 mm (0.0059"), feed rate 1.800 mm/min (71 IPM)
G - 8.000 RPM, depth of cut 2.5 mm (0.1", half the diameter), chipload 0.1 mm (0.0039"), feed rate 800 mm/min (31 IPM)
H - chipload 0.12 mm (0.0047"), feed rate 960 mm/min (38 IPM)
I - 18.000 RPM, depth of cut 2.5 mm (0.1", half the diameter), chipload 0.1 mm (0.0039"), feed rate 1.800 mm/min (71 IPM)
The second picture - details of A - I slots.
The third picture - cleaned slots. I noticed that chips are melted to the left side of the slot (cut direction left to right on the picture). Right side of the slot looks better than the left side.
Can you advice what to try next? Looking at the second picture, it seems to me that chips are not extracted at all from the tool thus recutted and melted.
Am I using incorrect tool? This one is recommended for plastic. Tools is new, sharp.
Should I increase the chipload? I did not like sound of cutting now already and I am afraid to push it more. Or, are chips too large and stuck in the tool?
Should I use different depth of cut? Most of the advisors online suggest to start even with 1xD depth (like Onsrud cutting data sheet for similiar tool).
Should I blow air on tool to support chip extraction? Unfortunately I do not have any air compressor, only a vac with ability to reverse air flow.
I tried to use this tool for full depth finishing pass on one of the edges of the acrylic piece and the result was very good. Produced chips were nice - uniform, no melting observed. It was outside profiling with no obstacles for exiting chips in contrast to slotting described above.
Thanks.
