584,837 active members*
4,941 visitors online*
    Mar 2013
    12
    CNC plasma ARC BREAK ALARM
    I just got my cnc plasma machine from china, as I tried to get it up for running there is problem that I have and I hope someone can help.
    when I tried to cut a piece of metal, it doesn't start, it keep popes up message box say " ARC BREAK ALARM" I tried it manually the arc work. sometime the machine runs but not arc, doesn't cut at all. any idea work could be wrong? I was told be the guy who I bought it from I need to clamp it on the material not on the bed, and I need to adjust the voltage higher. Is that right?
    Anything will help. Thanks
    Feb 2019
    Re: CNC plasma ARC BREAK ALARM
    I know this is a really old post but I am having the same problem. Any suggestions? Thanks, Cal
  1. pc shutsdown and alarm goes off when plasma torch starts
    By russellbecks in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-28-2015, 10:14 AM
  2. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  3. alarm 950 fuse break otc
    By actmach in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-01-2009, 01:18 AM
  4. Break in Z
    By davide.castro in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2008, 02:14 PM
  5. fanuc ot-c alarm 950 fuse break
    By actmach in forum DNC Problems and Solutions
    Last Post: 07-23-2005, 06:05 AM
