585,932 active members*
3,731 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB300-M. X axis servo vibrates whit peaks at every 3 mm increment, any idea?
Results 1 to 15 of 15
    Sep 2010
    13
    Check out this video, in the beginning when x axis move slow you can clearly hear the vibrations from the servo motor, have already tried a new encoder, same problem. Any suggestions?
    The noise you hear from the machine is not from the cutting tool, it just sounds like it, it is from the servo motor
    https://youtu.be/mIToZ6TPSpY
    Jun 2015
    4154
    Re: Okuma LB300-M. X axis servo vibrates whit peaks at every 3 mm increment, any idea
    i don't know what to say exactly, but if i would hear strange noises, like this, than :
    ... i would try to be sure if it is the electronics or the mechanics
    ... let the motor work without load, disengage the turret, and hear it only spiniing the screw
    ... if same thing, than disengage the screw
    add / remove parts from the chain, and locate the problem
    i won't say and i wish that there is no paralelism problem
    do you have peeks all over between x+ and x -, or only near x+ ?
    Feb 2009
    6028
    Check to see if X and Z drive units are the same, and swap them. I'm pretty sure on those even if the Z is a larger unit, you can still swap for testing. If noise is still there, you should megaohm the X motor for shorts.
    Sent from my A3-A20FHD using Tapatalk
    Jun 2015
    4154
    those 3 mm trigger some idea ? like is it the "screw pitch" or " motor brush " ? i don't know those dimensions, but if it repeats at "3", than there is a "3x" location that must be inspected / this is all i can say
    Feb 2009
    6028
    No brushes, AC motors, and 5mm pitch screws usually.
    Sep 2010
    13
    I think the noise is electro / acoustic generated, all mechanical is ok. The vibration peak differ from max to almost nothing just inside of a window on 0,3 mm in 3 mm increments, if we keep the position on top of the vibrating peak the servo overloads in a few seconds and the alarm 13 appear on the servo display, when the servo is operated at higher speeds its almost no problem, and you can not hear the vibrations/ oscillation.
    I think i will megaohm the motor, the servo module is a double servo, i will see for the possibility of swapping between x and z output.
    I have been working as a professional Mazak technician for almost twenty years but newer experienced a problem just like this :-)
    Thank to all of you for your advice's
    Regards
    Ralf Halvorsrød
    Sep 2010
    13
    Jun 2015
    4154
    you may leave it overloaded / close to it, and inspect it while in this state, but i am not an electronist
    3 mm / pitch should give an electronist a start point
    i saw that such devices may be inspected on an outside stand
    now u know them all
    Sep 2010
    13
    In this profession there is not one day whit out some kind of surprise (flame2)
    Aug 2011
    419
    Faulty drive unit, try to change complete unit (axis card+unit) .
    "Imagination is more important than knowledge."
    Sep 2010
    13
    How sure are you on this Kurmay, on a scale from 1 to 10
    Jun 2015
    4154
    just kidding : 10 / 10 > get a new cnc maybe it comes with same issue ...
    Sep 2010
    13
    Swapped the servo drives, problem jumped to Z axis. It is a two channel servo drive by the way ;-)
    Jun 2015
    4154
    hy ! how it works ? you said you got a new encoder for X, did u manage something with that servo ?
    Sep 2010
    13
    Hei there. We had to change the drive unit, possible faulty output transistors on the inverter. Machine works well after new drive unit was installed :-)
  1. Okuma LB300///OSP U100L
    By iffe123 in forum Okuma
    Last Post: 08-25-2023, 04:30 PM
  2. DC Servo Vibrates on Fanuc 6M
    By parametric.ms in forum Fanuc
    Last Post: 08-06-2022, 08:11 AM
  3. Okuma LB300 Parts Manual
    By TonyW in forum Okuma
    Last Post: 08-02-2021, 04:26 PM
  4. Okuma OSP U100L serial on a LB300
    By fomaz in forum Okuma
    Last Post: 04-24-2013, 06:59 AM
  5. Looking for Okuma LB300-W Lathe Specs
    Last Post: 02-28-2011, 09:43 PM
