585,974 active members*
4,269 visitors online*
    Aug 2010
    134
    Acoustic Guitar Neck Joint Fixture
    In this episode we begin the process of building a neck joint fixture for guitars. It will also serve well as a tool for doing the heel graft inlay as well. First steps are to cut up all the parts and assemble the base.
    Thanks for watching!
    https://www.youtube.com/watch?v=gb1ovFpV6ig
    Jason Beam
    Sacramento, CA
    Aug 2010
    134
    Re: Acoustic Guitar Neck Joint Fixture
    This week, the routing templates get cut on the CNC and fitted to the fixture. After that, i set about making the vise that will hold the body in place while routing. Things are moving along well!
    https://www.youtube.com/watch?v=UqATi6VNZSU
    Jason Beam
    Sacramento, CA
    Aug 2010
    134
    This episode, I finish up getting the 'neck flap' mounted to the fixture with a little creative clamping. Then I also get the body vise jaws made and mounted so that part is done. After that, a little template mounting and things are almost done. Just a couple more pieces and we can start test cutting!
    Thanks for watching
    https://www.youtube.com/watch?v=qbG139iGKBU
    Jason Beam
    Sacramento, CA
    Aug 2010
    134
    This week the jig is completed by making the neck clamping system and then doing a couple of test cuts to ensure the templates work correctly. The final results are quite surprisingly good and I'm very pleased with how the jig turned out.
    https://www.youtube.com/watch?v=yYks7BCG_nM
    Jason Beam
    Sacramento, CA
  1. Replies: 6
    Last Post: 03-25-2021, 10:01 AM
  2. Acoustic Guitar
    By HelicopterJohn in forum MetalWork Discussion
    Last Post: 03-18-2013, 12:37 PM
  3. Rhino - Neck/Head Joint
    By nenoneno in forum Musical Instrument Design and Construction
    Last Post: 11-04-2010, 08:19 PM
  4. Anyone made an acoustic guitar?
    By NeoMoses in forum Musical Instrument Design and Construction
    Last Post: 01-02-2007, 01:45 AM
  5. Acoustic Guitar Rosettes
    By jemmyell in forum Musical Instrument Design and Construction
    Last Post: 07-17-2003, 05:26 AM
