585,902 active members*
4,016 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Champion H-Square CH1912 As frame for 3 axis machine.
Results 1 to 19 of 19
    Nov 2016
    39
    This is my first post here so a quick intro (skip to the text in bold if you want to get straight to the fun parts).
    I have been machining moulds and dies for most of my life, from age 15-20 I was a machine operator for my dad running some extremely old pantographs, lathes and other equipment (all manually operated). A few years later I was introduced to cnc machines by one of my dad's customers and offered a job. Since then I have designed for and operated many different machines ranging from 3 and 4 axis cnc (Kuhlmann, Prokomat, Roland, gravograph, with software ranging from dos to windows based) and have also worked on several laser engravers (c02 and yag), 3d scanners both probe and laser (NextEngine, Roland) as well as vinyl printers and cutters and many other machines in between.
    Not only have I operated these machines I have also been responsible for their repairs and maintenance so my knowledge and experience with them should help me with this project.
    I was recently given an old Champion H-Square 2d Engraver.
    I have no software or manuals for the machine, in fact I don't even have a pc with serial port to plug it into.
    The website that I keep getting referred to is also extremely outdated, none of the download links work and sending them an email results in a permanent failure ( Index )
    First prize for me right now would be to find a way of doing a test cut before I even bother with changing motors and controllers, who knows, there may even be some software out there that would allow me to do some xyz cutting with the machine as is but I doubt that, hence this post.
    I will update as I go along and maybe someone will find this handy in future, I have seen these machines selling online for $25 so it may make an excellent base for a little "cheap" diy project.
    If anyone else has any experience please shout, I would live some input or feedback.
    I pulled this machine off the top rack in a store room where it has been standing uncovered and practically untouched for the last 10 years.
    It had a thin layer of cutting oil and dust protecting it from rusting and moisture
    "Z" Stepper Motor.
    Machine and controller labels.
    I gave it a quick wipe down with a bit of degreaser to get rid of the excess muck and asked a friend to bring me the machine as it would not fit in my car.
    I took the controller and cables as well as the cutters and other accessories that were still around home with me.
    Yesterday the rest of it arrived and I put it together.
    I manually turned the x and y screw by hand to check that all the bearings are in place and nothing had seized.
    The z has very very little tension when there is no power to the motor so that can easily be moved up and down.
    After having the z axis grind into the top a few times while I was trying to get the machine to initialise I found that the Z's limit switch had come loose and that the bit of brass sheeting being used to press the limit switch is suffering from metal fatigue.
    Once that was fixed the machine travelled home perfectly.
    The spindle also turns on and off without a hitch.
    Nov 2016
    39
    Re: Champion H-Square CH1912 As frame for 3 axis machine.
    Plans for this machine:
    If anyone has any suggestions at all please shout. This is the first time I have attempted to rebuild a machine of this nature in this manner.
    I will add more photos of the machine as it is at the moment tonight or tomorrow.
    1. Try and find compatible (and affordable for testing only) software and drivers so as to try and make it run as is so as to test all screws, limit switches etc.
    2. Find appropriate 4 or 5 axis controllers/kit to replace the current set with.
    I am thinking of using this kit:
    Stepper Motor 3 Axis CNC controller Kit NEMA 23
    Package Contents:
    3 X M335 Microstepping Driver
    3 X Stepper Motor NEMA 23
    1 X 5 Axis Breakout Board
    1 X 24V 15A Power Supply
    1 X LPT Parallel Cable
    1 X USB Cable
    1 X CD Driver
    Actual parts in kit.
    I want to use as much of the current parts as I can so will not be buying more limit switches and so on for now.
    I wish I could keep the current stepper motors in place but it seems it would be cheaper to replace them for my intentions.
    3. Lower the working table as much as I can and raise either the X, Y or both rails if at all possible so as to increase my Z working area.
    4. Do extensive cut tests in both 2d and 3d, cut pyramids, domes, planed angles etc and make sure everything is running perfectly. Modify whatever needs it.
    5. Cut some plates to fit the new parts into the current controller box (there is plenty space inside it) for the new breakout board, stepper motor drivers, power supply and whatever else needs it. Modify and improve airflow and ventilation so that the new parts don't produce excess heat.
    6. At this point I may or may not decide to add an A Axis going down the right side of the working table (I may even cut or mill myself an area for the motor and working space to fit into but want to make it removable in case I want to engrave larger things on the entire working table).
    7. Once the machine is complete, installed and tested I want to tear the whole machine down, do maintenance on all the screws, bearings, moving parts etc.
    8. While all the plates and frame are separated from the electronics and mechanics I want to respray them and possibly personalise them
    9. Final step is to put the whole thing together and hopefully get years of play time out of it.
    I want to mostly cut plastics and wood but would also like to be able to cut into softer metals as well. Will the NEMA 23 motors handle this?
    Nov 2016
    39
    Some pictures of the controller. Attachment 338712Attachment 338714Attachment 338716
    The current spindle motor.
    Main reason I'll keep the rest of the controller, it's 110v and where I come from everything is 220v.
    I'll put a push to break switch at the top limit of the Z axis to turn it off after a cut is complete.
    Attachment 338718
    Served by a Droid
    Nov 2016
    39
    Started getting a look at the insides tonight.
    Most of the torx screws on the machine have been stripped by Allen keys and had locktite applied to the threads, makes opening any panel a serious mission. I have ended up resorting to a mix between a dremel and a drill.
    Attachment 338810
    I'll end up having to do a bit of cosmetic work once the machine is ready.
    I managed to get the Y motor panel off and started with the X panel but family life and work takes priority so I only have around 30 minutes a day during the week for this project.
    Biggest stepper of the 3.
    Attachment 338812
    Attachment 338814
    Here are some pictures of the x from the bottom of the machine.
    Attachment 338820
    Attachment 338818
    Attachment 338816
    I'm really starting to think I should see if I can find a stepper motor driver and controller that can run these.
    Any advice would be greatly appreciated
    Finally, some random pictures of one of the 6mm shaft cutters that came with the machine.
    Excuse the filthy outside table, it's been rained on and my pet chicken gets mud everywhere.
    Attachment 338822Attachment 338824Attachment 338826
    Nov 2016
    39
    I tried getting it to run via engrave-lab trial but no luck.
    Attachment 339260
    Old crt monitor I've had for years. Obviously not part of the system.
    Decided that enough is enough and started stripping it down so that I can give it a good wash, clean and sand all the panels and get everything ready to be repainted.
    I started by marking all the connectors then getting dismantling whatever I can.
    Attachment 339262
    Finally getting a look at the trails and screws, they need a good cleanup but everything still looks sound.
    Some of the bolts are imperial so I'll borrow a set from work and get the X and y motor off tomorrow. I'll be replacing all the torx and imperial nuts and bolts with metric.
    Attachment 339264
    Attachment 339266
    Attachment 339268
    Someone got here before me. Another bolt to drill out.
    Attachment 339270
    Everything laid out and marked as it came off the machine.
    Attachment 339272
    Attachment 339274
    The Y Stepper is the same as the Z Stepper. Tiny little thing. I may end up replacing it and keeping it as a spare for the Z.
    Anyway, back to normal chores.
    Served by a Droid
    Nov 2016
    39
    Stripped all the old power supplies out of the controller yesterday, will use the 220v to 110v converter for the spindle that came with the machine and may use the Stepper motors supply for powering those (still getting verification that it won't blow the new breakout board and drivers).
    Attachment 339528
    Served by a Droid
    Nov 2016
    39
    Bits of the electronics I will likely reuse (limit switches and induction motor starting cap not in here).
    Attachment 339768
    Nov 2016
    39
    Quick update.
    Just about finished stripping the frame down to the bone for a very good cleaning and likely painting.
    I am considering leaving the painting for now, stripping it again after 6 months or so of use, upgrading the spindle then powder coating it.
    Found a few bearings, many many bolts and screws that need replacement as well as several holes that need re-threading or helicoils but other than that all good.
    It's a lovely solid cast frame and with new electronics as well as some future modifications to the screws and rails it will last another decade.
    Attachment 340438
    Oh i found a reasonably priced nema 23 kit that I'll be buying, I'll use these motors for something else.
    Served by a Droid
    Nov 2016
    39
    I have taken the machine completely apart.
    I used around 1l of degreaser and a high pressure sprayer on the frame and anything else that could get wet.
    I then drilled and rethreaded some holes on the y axis used to adjust bearing pressure on the rails and have started putting it back together again.
    X and y now both move freely with absolutely zero play
    I'm not touching it again till I have my motors in hand so I have covered it up and am patiently waiting.
    Served by a Droid
    Aug 2009
    655
    Yeah these machines are solid!
    I'm doing similar on an old one (more actively as of late).
    I'm trying tinyg and pibot. I strongly suspect tinyg will work best but it's just coming next week.
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Nov 2016
    39
    Quote Originally Posted by gfacer2 View Post
    I got the mechanics working but till now not had time for the electronics. Going to get to that very soon at least. Should have my evening's free from next week.
    Note: Tapatalk and SwiftKey used for above.
    Jul 2007
    1602
    Those were also sold as a New Hermes Vanguard
    Some parts are available here: NEW HERMES VANGUARD 1219 PARTS : Quality One Engraving, Your #1 Source for Engravers and Engraving!
    I have had one sitting for about 6 years now. I should get around to doing something with it...
    bob
    Nov 2016
    39
    Finally got a few hours.
    What the case looks like right now.
    Nov 2016
    39
    Not posted here for a while but here is some of the progress. Still lots to do but it's all coming together nicely now.
    Controller is now ready and waiting. I have started with the wiring, reassembling and improving on the Z axis assembly and am waiting for my flexible shaft couplings to arrive.
    I have mach 3 behaving properly etc as well
    Sent from my SM-G935F using Tapatalk
    Nov 2016
    39
    Current state of machine:
    Been waiting for months for my flexible shaft couplings to arrive, they finally did on Monday.
    So now motors are in place and I'm busy doing the wiring from machine to controller.
    Hopefully I'll do my first test cuts by the weekend.
    Nov 2016
    39
    First run.
    Was very late last night so one terrible video after quickly wiring up the steppers.
    https://youtu.be/70oZblJyQok
    Nov 2016
    39
    Life got in the way and I ended up leaving this project on the bench for months.
    I finally got back into it a few weeks back.
    I swapped some linear bearings out for new ones, modified motor tuning, changed the Z and x flexible shafts for solid ones (too much play in the design for flexible shafts) and numerous other things.
    I'm nearly at the point where I am happy with the result.
    Some videos of it running below. Just 2d cuts but it is capable of 3d (I'll upload it anyone is at all interested).
    https://youtu.be/LhJMtmq4SRE
    https://youtu.be/N8Frko-Rpzk
    https://youtu.be/sRMPuyHmIkk
    Nov 2016
    39
    Oh the result of that cut.
    It's around 33mm total
    Nov 2016
    39
    Playing
  1. Need Help with Prussiani Champion Machine
    By PrecisionStone in forum Glass, Plastic and Stone
    Last Post: 03-08-2016, 10:52 PM
  2. frame of 4 axis machine with ATC function
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 11-29-2014, 04:29 AM
  3. Mach Motion $7.50 Square 23 Frame Steppers
    By machmotion in forum News Announcements
    Last Post: 07-01-2014, 09:44 PM
  4. Ornate square picture frame
    By aarggh in forum MetalWork Discussion
    Last Post: 01-11-2014, 09:30 AM
  5. Steel square tubing for frame
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 08-20-2005, 02:44 PM
