585,970 active members*
4,424 visitors online*
IndustryArena Forum > CAM Software > Vectric > can't find Mach3
    Nov 2016
    can't find Mach3
    Hi I've just started using Cut2D while running mach3 in background, after I finished my toolpaths etc i tried to send to mach, but got message, Failed to attach to mach, then clicked ok and got message, Failed to find running instance of Mach, what am I doing wrong, I saved progect then I could not find it in , Thanks .
    Nov 2012
    1267
    Re: can't find Mach3
    See if this old thread has some useful info:
    http://www.cnczone.com/forums/diy-cn...put-mach3.html
    Feb 2012
    8
    I think your best bet would be to save your file to your desktop using the post processor for your machine, then open the file with Mach 3...that will keep you from losing the file if something happens in the transfer...just my opinion
    Artsoft broke this "feature" a long time ago,and never fixed it.
  1. Neat find: MAch3 screw mapping + beginners papers w tons of detail!
    By countryguy in forum Shopmaster/Shoptask
    Last Post: 05-06-2015, 08:57 AM
  2. Looking to find a home for a Bridgeport Series 1 CNC (was BOSS 5, now Mach3)
    By bbuonomo in forum Bridgeport / Hardinge Mills
    Last Post: 04-29-2014, 01:59 PM
  3. Mach3 anyone find it unreliable
    By RonCooper in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2011, 07:59 PM
  4. Where to find Mach3 turn .set layout file
    By LTP in forum Mach Lathe
    Last Post: 01-01-2011, 03:36 PM
  5. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
