585,880 active members*
8,015 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki CV-500 connection with PC...
    Nov 2016
    Hello everyone,
    I'm working with a Mori Seiki CV-500, and unfortunately they are a neophyte in this field (I am a Computer Engineer).
    I ask you, what is the easiest way to transfer a program from a PC to the machine? Of course it's the serial port, but I tried it and I from 'always error (usually framing error).
    First, I have to use that port, the NC or the GOP? What is the difference between the two?
    You have to use some special program to transfer or you can simply copy the from a DOS window on the com port?
    Of course I tried to set symmetrically in all parameters with which baud rate, stop bits, parity, etc ... but me 'always mistake ...
    And what about the cable for connection on rs232 port? It's correct this cable:
    Machinery RS232 communications settings for CNC controls including fanuc and mitsubishi
    Thanks in advance to those who want to help me ...
    Greetings...
    A:I
    Apr 2010
    27
    Re: Mori Seiki CV-500 connection with PC...
    Hello
    Could you solve the problem?
    I’m using “OPEN COMMUNCATION FOR FANUC (V50.0)” to transfer part programs and other data with all FANUC CNC (old 0, 16, and new 31i).
    It´s the easiest and best program I know.
    It works very well with both RS232 and ETHERNET connection.
    I also use it for DNC operation.
    Attached with the program run file you can get the detailed manuals for the setting up.
    You can download from the following link:
    Open Communications for FANUC CNC - Free Download
    also from:
    Open Communication for FANUC Download
    Regards
    Feb 2009
    6028
    Mitsubishi Control...
    Those early ones don't actually use the GOP for comm. Any serial program should work, framing error could be stop bit and word length not matching. All parameters for that should be in the Mitsubishi manual.
    Sent from my A3-A20FHD using Tapatalk
    Apr 2010
    27
    According to my experience not all the Serial Communication programs work with FANUC CNC. In fact only few ones work properly.
    Especially when working in DNC mode and transferring data at high speed (> 9600 bauds).
    I think this is because FANUC CNC have a very small input buffer and require a quick response from the communication program in the PC.
    As far as I know “Open Communication for FANUC” is the only application that can be used with all FANUC CNC and both RS232 / ETHERNET communication.
    If anybody know other application I could try in our machines as we have very old FANUC CNC with RS232 (0,16,21) and also new CNC with ETHERNET (31i).
    Nov 2017
    5
    Hello,
    please, could you help me?
    I am seeking the Parameters (also PLC Parameters) and Instruction book
    for Mori Seiki CV500-A, year 1998
    please let me know if you can help
    All the Parameters have been lost.
  1. Mori seiki SL1?
    By Redzilla in forum Mori Seiki lathes
    Last Post: 05-17-2016, 11:02 PM
  2. Mori Seiki SL-1
    By Chevalier180D in forum Mori Seiki lathes
    Last Post: 10-16-2013, 07:18 PM
  3. Mori Seiki SL-250
    By CASAREZAARON in forum Community Club House
    Last Post: 08-28-2013, 05:29 PM
  4. MORI SEIKI MV 40B
    By jovanov in forum Want To Buy...Need help!
    Last Post: 02-06-2013, 12:41 AM
  5. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
