585,753 active members*
4,680 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Bison Gear Motor Modell 016-500-9115 / Haas part number 62.0050
Results 1 to 5 of 5
    Oct 2005
    34
    A customer uses a Haas Micron VCE1250,
    The chip conveyor of this machine is original switched on and off through a board. This part of the board is burned, so the chip conveyor is not working at all.
    The local electrician cuts all wires, and after this, he didn't understand anymore, and ran away, leaving me with the problem.
    So I made an ordinary switch on the machine: left/stop/right with a few relais.
    Now I want to hook up the motor, but run to an unexpected problem.
    This motor is a made by General Electric, 5KCP20L G8353 T CL B INSUL
    The assembly is from Bison Gear Motor: Modell 016-500-9115
    Out of this motor comes 5 wires:
    Blue
    White
    black
    red
    brown
    There is also a capacitor.
    I have tried everything to clarify the connection of this gear motor.
    I`ve contacted Bison USA and got the information from Canada. Its a motor for Haas. This is located in Belgium.
    The representation in Germany could not say anything. They give the question to Belgium.
    Belgium wants to give no information to me !
    Any help would be highly appreciated.
    Thanks in advange and greetings from The Netherlands!
    Attachment 338842
    Feb 2010
    1184
    Re: Bison Gear Motor Modell 016-500-9115 / Haas part number 62.0050
    You are in luck as I have this exact motor apart.
    Motor ----- Cable
    Red to Cap to Red
    Blue to Orange
    Brown to Blue
    Black to Black
    White to White
    Green(cable) = Ground
    Yellow(cable) = Not used
    Oct 2005
    34
    Thanks, that makes things a bit more clear!
    As I want to drive the motor with ordinary relays I made a small drawing,
    Do you thinks this will work?
    Nov 2018
    Can you please share the electrical drawing if possibel?
    Oct 2021
    Sorry for inconvenience you faces, really disappointed.
    If you are planning to purchase a new geared motor then I can helps you deliver the high quality & efficiency product.
    We have a wide range of gear box & geared motors and also open for develop according to your requirements as well as.
    This is one of our product I can consider- Helical Gear Box & Geared Motor
    Characteristics-
    Optimised size/performance ratio
    Highly efficient and low-maintenance
    Designed for permanent operation under rough conditions
    Housing produced from high quality grey cast iron with rugged walls
    High axial and radial forces on the output shaft are permitted
    Extremely torsion-resistant
    Hardened helical gears produced from high quality steel with precision ground tooth profiles
    Diverse attachment options.
    You can purchase this gear box from https://www.rehfuss.com/en/ with worldwide delivery.
  1. AL-2 need a part number please!
    By warbirdMD in forum Mori Seiki lathes
    Last Post: 07-28-2015, 06:25 PM
  2. Replies: 1
    Last Post: 06-24-2013, 04:50 AM
  3. Shizuoka AN-S back gear: part number?
    By Chopsaw in forum Knee Vertical Mills
    Last Post: 05-23-2011, 06:23 PM
  4. Diameter, Pitch, Number of Teeth, etc. on Spur gear?
    By SlimJimmy in forum Waterjet General Topics
    Last Post: 12-04-2008, 05:10 AM
  5. SL-25 part number
    By Micro in forum Mori Seiki lathes
    Last Post: 10-01-2008, 05:03 PM
