585,930 active members*
3,664 visitors online*
Page 10 of 10 8910
Results 181 to 198 of 198
  1. #181
    Apr 2016
    109
    Re: RAPIDTURN VIDEOS
    What are the best steel choices to make the spindle nose plate and other gang tool plates out of?
    Do you think 7075 aluminum would hold up and be rigid enough? I've got a few 3/4" plates of that lying around that are almost perfect size.
  2. #182
    Feb 2007
    1538
    Hi Advil.
    I used mild steel about 1" thick from memory.
    Its not that alum is not rigid enough - but best practise is steel or cast iron because it has similiar thermal expansion - alum is much more and in different temperatures tools etc will be in slightly different positions.
    Hence RapidTurns diameter inaccuracy issue. But it may not actually be that much depending on your climate etc. and would be ok for less high precision work. Cheers Cliff
  3. #183
    Feb 2007
    1538
    Hi Folks
    I recently decided to demonstate RapidTurn again so I brought it out of mothballs to do a parts run - this time with auto toolchanging and auto multiple parts.
    Here is part 1 (not yet showing multiple parts per setting) - Cheers Cliff
    https://www.youtube.com/watch?v=q-JQFu6iRmA&t=767s
  4. #184
    Nov 2007
    2151
    Good informative video. Nifty how you used the z axis as a vertical shaper.
  5. #185
    Apr 2016
    109
    I've learned something from all Keen's videos. Also, I wouldn't have been willing to order a Rapidturn without this much info available. It's greatly appreciated.
  6. #186
    Apr 2013
    1788
    +1
    I've also learned lots from Keen's videos
  7. #187
    Feb 2007
    1538
    Thanks Guys!
    Here is Part 2. Cheers Cliff
    https://www.youtube.com/watch?v=BxSAIzebnZs&t=9s
  8. #188
    Feb 2007
    1538
    And here is part 3:
    Finish setting up tools - and start on setting tool offsets.
    Cheers Cliff
    https://www.youtube.com/watch?v=WPo_KK-S1yA&t=1s
  9. #189
    Feb 2007
    1538
    And here is part 4 - finish setting offsets and run.
    Cheers Cliff
    https://www.youtube.com/watch?v=oWcmy9dig5U&t=552s
  10. #190
    Feb 2007
    1538
    This video outlines multiparts per cycle. Cheers Cliff
    https://www.youtube.com/watch?v=XEEofg4zp-g&t=5s
  11. #191
    Feb 2007
    1538
    And finally, a brief summary.
    If you have a RapidTurn, please post your thoughts and experiences here!
    Cheers Cliff
    https://www.youtube.com/watch?v=f7VcCALjdkg&t=2s
  12. #192
    Jun 2006
    3063
    Hi Cliff - Good info and thought process even for those of us that don't have a RapidTurn. I was wondering, though, if you'd ever looked into the InTurn 4th axis system that is described at WebPageMain ?
  13. #193
    Feb 2007
    1538
    Quote Originally Posted by MichaelHenry View Post
    Hi Mike - No I only know a little about InTurn . Any information on it - please post here. For example, how easily does it interface with Tormachs electrics and Pathpilot?
    Cliff
  14. #194
    Feb 2007
    1538
    Cliff
  15. #195
    Jun 2006
    3063
    Quote Originally Posted by keen View Post
    Cliff
    I have an early InTurn from back before PathPilot was out but never set it up as the job I bought it for went away. I'm pretty sure that Steve either has or is planning to support Path Pilot so I may give it a shot again. One minor issue for me is building an enclosure the drive and controls. I usually put off that sort of task far too long, as in this case.
  16. #196
    Aug 2006
    51
    Just received my RapidTurn and it had 2 issues (so far) and 1 that may become a problem:
    1) missing pin/key for the collet. I had a roll pin on hand and installed it myself
    2) bad inductive sensor. Have a call in to Tormach, bet they are slow to respond. I purchased a replacement on Amazon but would rather get one from Tormach that has the connector wired so I don't need to figure it out.
    3) ticking sound that is not 1 per revolution so it may be a bearing ball ??
    We'll see how it all turns out when I finally get to cut my 1st part after I fix the sensor
  17. #197
    Jul 2008
    81
    Hello GTOGuy,
    I am anxious to read what you learn about the Rapidturn. When did you order yours? Was just on Tormach's web site and they are back ordered. Have followed most of Keen's adventures with same. Need a CNC lathe capability in my shop. Not considering new Tormach CNC lathe cause its too small for the money. (my opinion only) Obviously, Rapidturn on an 1100 has limitations too but I have a full size lathe but would like to be able to CNC a bunch of repetitive small parts with Rapidturn.
    Cismontguy
  18. #198
    Aug 2006
    51
    Quote Originally Posted by cismontguy View Post
    Hello GTOGuy,
    Cismontguy
    They had a few in stock when I ordered mine a couple of weeks ago so they must be popular.
    I wanted a CNC Lathe and am just plain out of room in my garage. I have a large manual lathe that I am not willing to part with so my next best option was for the RapidTurn. It is a bit underpowered I suspect but should allow me to cut threads on Al, Brass, and steel (slowly I imagine) for my many one-off projects. I also sometimes make lathe parts with angles, tapers, and grooves to the CNC capability will speed that up.
    Heard back from Tormach right after I posted this (I left a frustrated message about wait times and disappointing start up problems and they are shipping out a new sensor right away. They are very good once you can get them into the problem. I hope the sensor solves the problem as the RapidTurn will not function in SF mode without it. theya also said there is no collet pin/key in their design (even though there is a .125 hole for it in the rear collet support diameter. Never had a 5C collet system with out one but what can I say.......... I put a roll pin in anyway myself.
Page 10 of 10 8910
  1. rapidturn tolerance limits
    By TiO2 in forum Tormach Personal CNC Mill
    Last Post: 09-17-2016, 11:00 AM
  2. First Impressions of the Rapidturn
    By Tbkahuna in forum Tormach Personal CNC Mill
    Last Post: 08-16-2016, 03:32 AM
  3. RapidTurn and PCNC770
    By kstrauss in forum Tormach Personal CNC Mill
    Last Post: 07-31-2016, 03:57 PM
  4. RapidTurn and Fusion 360
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 07-31-2016, 03:35 PM
  5. RapidTurn Order
    Last Post: 07-12-2016, 08:35 PM
