585,991 active members*
5,125 visitors online*
IndustryArena Forum > CAM Software > Alphacam > POST Processor - Based on machine, or CAM software?
Results 1 to 6 of 6
    Oct 2016
    6
    Hello all. I am using AlphaCam and CabinetVision, and have 2 different posts for them. I want to try using VCarve machinist, but they have their own selection of POST processors available. This got me to thinking...is the POST processor specific to the machine (or more specifically, numerical controller), or are there proprietary commands/values in the POST based on the CAM software as well? In other words, do I need a custom POST for every software I use, or will one post that works well work for multiple software platforms? Thanks for the help!
    Re: POST Processor - Based on machine, or CAM software?
    Each CAM program uses their own format for their post processors. So a post processor for AlphaCAM will not work with Vectric software.
    In addition, the post processor is tailored to the specific machine.
    If you have 10 CAM programs and one machine, then you'd need 10 post processors.
    If you have 1 CAM program and 10 different machines, then you'd need 10 post processors.
    Oct 2016
    6
    Makes perfect sense. Thanks so much for the clarification.
    Apr 2015
    327
    Quote Originally Posted by thegraz22 View Post
    It is as said ger21 in a Alphacam and Cabinet vision is advantage that CV use Alphacam for generate NC code. So post have same syntax, but CV has some own rules than must be in a 90 percent other post then for Alphacam.
    Marek
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Aug 2014
    19
    I use Alphacam too and for some reason I need two posts for the one machine.... One for when I add a program stop and one for when I don't. Anyone know why?
    Apr 2015
    327
    It depend on a post writer. Im always recommended one post for one machine. I do not know logic in your post code. If you can send me this i can check it.
  1. post processor for euromac cx1250 software(eurowin)
    By sjh in forum Post Processor Files
    Last Post: 11-24-2014, 04:39 PM
  2. Replies: 1
    Last Post: 07-08-2014, 09:54 AM
  3. cam software with hurco post processor
    By Mag Man in forum HURCO
    Last Post: 07-26-2009, 05:05 AM
  4. Artcam Post Processor For SMC 1500 software
    By Brenck in forum Controller & Computer Solutions
    Last Post: 06-20-2009, 09:54 PM
