Is it possible to make a custom program M Code without end of program which is M30 or M02 ?
The requirement is such that the operator needs to login into the machine when he arrives for his shift and if a part program (a long cycle time one) is already running on the machine then he has to run the login M code from MDI mode after executing feed hold in single block (after completion of the block under execution). Any M30 or M02 at the end of custom M Code program will end up resetting the auto cycle which defeats the whole purpose.
yaji
