584,871 active members*
5,294 visitors online*
Results 1 to 7 of 7
    Feb 2008
    4
    Have a DSP 0501 that I bricked, need firmware
    I have a DSP 0501 controller (looks exactly like the RZNC-0501, but it must be a clone. I accidentally loaded the RZNC firmware and now the hand controller is hung at a "Piracy Control" screen. I honestly didn't know that it wasn't an RZNC controller, they look identical. The only numbers I have to go by are "SQNC-0501HDDC -L07-100088". If anyone out there has firmware that will work with this controller, please help!
    Mar 2013
    4
    Re: Have a DSP 0501 that I bricked, need firmware
    i need language and logo file for sqnc 0501
    Jul 2010
    25
    Hi MDAVISTER,
    I have there same issue. Did you have any luck with this?
    Cheers
    May 2017
    I have same problem, too? Did anybody solve this problem ?
    LG-D802TR cihazımdan Tapatalk kullanılarak gönderildi
    May 2022
    Hello , did you solved the problem? Have you the right firmware for this controller? Im in the same sitiation as you described . thanks
    Sep 2022
    5
    Hello, good day. Did you solve the problem?, Apparently i have the problem.
    Jan 2023
    Hello evrebody! Maybe someone can help me? I also have RZNC controller in my CO2 laser. Accidentaly it has been broken. And I'm searching for firmware of these RZNC-6001 PBBE - L13-1.2(ZHB821)(Init version was RZNC-D5416/3/L13 1.2 (hgqdme8) and normal was RZNC-D5416/3/L13 1.2 (hgqdme853) ). Please hwo have the same laser machine sent to my email files newbin2 and other. Hope for your help. [email protected]
    Jul 2021
    5
    Hello, looking for firmwear for DSP 0501
    Mar 2022
    Hello everyone, I had this problem a while ago and since you also spent some time looking for the solution, I am sending you this firmware to reestablish the DSP interface. The only thing is that the internal menu has parts where it is in Chinese and in others it is in English. but it is not very serious, the good thing is that you can work with the DSP again.
    Attached Files Attached Files
  1. Problem with DSP controller RZNC 0501
    By oncoarse in forum Commercial CNC Wood Routers
    Last Post: 01-23-2023, 01:08 AM
  2. Looking for DSP Controller - DSP-0501
    By Andre09 in forum Chinese Machines
    Last Post: 11-09-2016, 02:39 PM
  3. Probleme with my dsp 0501 controler
    By wanouboy in forum Waterjet General Topics
    Last Post: 12-07-2013, 07:53 AM
  4. RZNC 0501 Plasma on/off
    By pyrohamish in forum Controller & Computer Solutions
    Last Post: 09-16-2013, 04:42 PM
