585,981 active members*
4,208 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Door hold interlocks for 1996 VF-6
Results 1 to 6 of 6
    Jan 2013
    32
    while most posters are looking to disable the door interlocks i am asking the opposite. our safety guy is requiring me to find a way to disable the "door hold override" setting #51 he is requiring that standard operators are unable to disable the switches. we have a few different machines but all are 1996 era controls. i am coming up blank on a way to do this other than having a HAAS tech come in and hard wire it some how. any suggestions?
    Nov 2007
    479
    Re: Door hold interlocks for 1996 VF-6
    how about a sign on the door itself. "disable door hold override = fired"
    Dec 2004
    126
    if you can`t trust the guys working for you fire them and get some you can ..... there safety has to start with them doing smart things ,, if you have to hold there hand to make them safe put them back on the short bus and let someone else enjoy them.
    Jan 2013
    32
    while i understand your position, i would guess you work for yourself or a small company. i personally find most safety stuff a hindrance but i work for a large global company where decisions are made 20 levels of management up the ladder and on the other side of the country or sometimes the other side of the world. someone somewhere sitting in their swivel chair behind a mahogany desk came up with the idea. its just my job to figure it out.
    Feb 2010
    1184
    Quote Originally Posted by steve pies View Post
    Your machine should have a parameter that when set, the machine will ignore SETTING 51; I don't recall the exact parameter at the moment though. However, unless you have a way to lock out the parameters, one could still re-enable the switch if so desired.
    Only other way I can think of would be to install your own door interlock switches and tie them into the E-Stop circuit. A call to the Haas factory (not your HFO) service support line or possibly the applications department might get you some better options other than just tying into the E-Stop.
    Good luck!
    Jan 2013
    32
    Quote Originally Posted by haastec View Post
    Good luck!
    the only parameter setting i can find is #57 safety circ and door spindle stop. the switches are being replaced at the moment so i will have to wait till they are replaced to test these out. thanks for the info.
  1. Mori Seiki SL35B Door Interlocks
    By Dean-R in forum Mori Seiki lathes
    Last Post: 01-27-2015, 12:01 PM
  2. Damn door interlocks!!
    By MarkSerbu in forum Haas Mills
    Last Post: 11-16-2012, 03:50 PM
  3. Cobra 42 Blue & Red Door Safety Interlocks
    By amacklin in forum Hardinge Lathes
    Last Post: 07-11-2012, 03:50 PM
  4. Door interlocks
    By WOODY210363 in forum Fanuc
    Last Post: 11-02-2011, 10:17 PM
  5. Door interlocks ???
    By phantomworks in forum Fadal
    Last Post: 11-22-2009, 12:55 AM
