585,970 active members*
4,298 visitors online*
Results 1 to 6 of 6
    Nov 2016
    5
    Mitsubishi FX20 contact problem
    We have 1997 Mitsubishi FX20 wire machine which we inherited about a year ago. It worked fine for a while but since about 5-6 months it started to show a contact with the IP settings of 4 and up. It works fine with smaller power settings. Initially that was happening only once in a while, now it seems to be working correctly only once in a while. I checked pretty much everything for any broken wires, so that is out of question. Beside that it would show the contact constantly not just on higher power settings. Did anybody experience something like that? Any suggestions what could be wrong?
    Pete
    Feb 2009
    51
    Re: Mitsubishi FX20 contact problem
    On top of the generator is a cover covering fans and some load resistors, check the resistance of the 2off 4ohm resistors, they are wired in series so should read approximately 8ohms. Sometimes we see 1 of these resistors go open circuit.
    Nov 2016
    5
    Thanks for the reply.
    I checked them and they seem to be fine.
    Feb 2009
    51
    Check the 6 avr's on the back of the sub unit.
    Feb 2009
    51
    Is your machine a straight FX machine or is it a FX20K machine?
    We hace a FX-20, Shows contact anda have that red led in MW416, This happens when we want to start to Cut. Someone know what happens?
  1. Mitsubishi FX20 EDM - X-Axis
    By jtmueller10 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-04-2014, 03:08 PM
  2. Mitsubishi FX20 Chiller issue
    By EDoucette32 in forum EDM Discussion General Topics
    Last Post: 07-30-2013, 12:50 PM
  3. mitsubishi FX20 software
    By eroprel in forum EDM Discussion General Topics
    Last Post: 01-23-2013, 02:21 PM
  4. Mitsubishi Wire EDM SX10 Contact problem
    By m_ross18 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2011, 05:22 PM
