Originally Posted by
109jb
Yes it is elementary and you are totally and absolutely wrong. You are the one making a fool of yourself. The horsepower at the arbor cannot change. Torque can and does, but the horsepower does not and the ratio doesn't matter. The horsepower at the arbor will ALWAYS be the same as at the motor.
Say you have a 1750 rpm motor that puts out 6 ft*lb of torque. That makes the motor a 2 hp motor because:
HP=RPM * torque / 5252 = 1750 * 6 / 5252 = 2 HP
Now put it in a machine with a 2:1 pulley ratio with the big pulley at the motor. The torque at the arbor will be reduced by 1/2, so torque at the arbor is now 6 * 0.5 = 3 ft*lb, but the RPM will be double so the RPM at the arbor is 1750 * 2 = 3500 rpm.
Now calculate the HP AT THE ARBOR using the torque at the arbor and the RPM at the arbor:
HP = RPM * torque / 5252 = 3500 * 3 / 5252, which magically calculates to 2 HP. no change at the arbor whatsoever.
Do the above calculations for whatever pulley ratio you like, the answer is always the same. The horsepower at the arbor is always the same as the horsepower at the motor regardless of the ratio.
