585,683 active members*
5,047 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > Lagun FT-1 Vertical Turret Ram Knee Mill ????
    Jun 2012
    18
    I have acquired a bit of a Frankenstein machine.
    I believe it's an early model Lagun with a Bridgeport Variable speed J -head.
    The question is regarding the serial number.....
    Mine is 4 digits. Everyone else's seems to be 5.....
    Any help identifying the base so I can start looking for the correct manual would be helpful.
    I did decide this must be a FT-1 based on the length of the bed. It's the only thing it could be.
    But there are a couple subtle differences in the drawings, anx I've looked all over for one with similar badging with no luck...
    My name placard logo thing on the side of the ram is different from any lagun I've found anywhere.
    Will try and figure out how to post pictures....
    Jun 2012
    18
    Re: Lagun FT-1 Vertical Turret Ram Knee Mill ????
    Serial number on the y-axis reads:
    SE-4526
  1. Lagun Knee Mill Retrofit
    By Need TECH Help! in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-20-2016, 05:07 PM
  2. Looking at a Shizouka ANS Vertical Knee CNC Mill...
    By bogiestl in forum Vertical Mill, Lathe Project Log
    Last Post: 09-30-2011, 04:24 AM
  3. Leveling a Lagun Vertical Mill
    By donl517 in forum Uncategorised MetalWorking Machines
    Last Post: 12-14-2008, 07:41 PM
  4. Lagun mill powered knee
    By jjclear in forum Knee Vertical Mills
    Last Post: 12-03-2008, 08:29 PM
  5. Hafco (Knee) Vertical Mill help
    By midworld08 in forum Knee Vertical Mills
    Last Post: 10-23-2007, 05:40 AM
