585,925 active members*
3,491 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > problem with tool/fixture offsets
    Mar 2011
    273
    First off, new to the fadal control. I have set my tools that seems the most common with touching off the top of the part, and leaving the fixture z offset blank.
    Decided to try and set my tool lengths off the table, and put in a fixture offset for the Z location. All worked out fine until the end of the program.
    G00 Z1.25
    Z1.255
    M5 M9
    G90 H0 Z0
    E0 X0. Y7.
    M2
    I over travel on the z on the g90 h0 z0 line.
    Then I decided to change it closer to the code to how my haas at work ends,
    g91 g28 z0
    g90
    e0 x0 y7
    m2
    and it bringz the z up to home, but then comes back down on the e0 x0 y7??? Not sure what the heck is going on there.
    I really don't care to set my tool lengths off the top of a part and have to change it with every op, or change of part, I much rather change the part offset.
    Is there a way to do this without jamming into the end of z travel like it did for me? I know about the mass modify for tool lengths, and will do it that way if I have to, but really rather not.
    thanks to anyone who can help
    ps, machine setup to run format 2
    Aug 2013
    18
    Re: problem with tool/fixture offsets
    Try this..
    g49 g28 z0
    M2
    Sent from my SM-G900R4 using Tapatalk
    May 2005
    53
    Try shutting off z and fixture offsets all on the same line.
    This works for me:
    G0 Z2.0 M5 M9 (just above clamps and part)
    X0 Y0 Z0 E0 H0 (turns off fixture and tool length offsets)
    M2
    I don't know if you can get away with a Y move on this line or not. We set up our machine in a similar fashion. a
    All tool lengths are established from a tool length probe. The Z value in the fixture offset is usually the difference in distance from the probe to the top of my part.
    Hope this long winded explanation helps!!
    Jim
    Mar 2011
    273
    Quote Originally Posted by Techman View Post
    This works for me:
    M2
    Jim
    Thank you. I tried your way and now it works without doing an overtravel. Very happy to program my tool lengths off the table and give the fixture z an offset, and now that has made it easier.
    thanks again guys
    Jan 2004
    3154
    I had the same stupid brain buster a bunch of years back when i decided to start using Z offsets as well
    www.integratedmechanical.ca
  1. Replies: 2
    Last Post: 10-24-2014, 04:17 PM
  2. problem with tool offsets
    By homerswitch in forum Uncategorised CAM Discussion
    Last Post: 04-07-2011, 12:00 AM
  3. Fixture Offsets with Tool Changes
    By HLF Ordnance in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2011, 06:29 PM
  4. Fixture offsets, X3
    By KevinV_MEI in forum Mastercam
    Last Post: 02-06-2011, 05:04 PM
  5. PROBLEM CHANGING TOOL OFFSETS
    By bmlw in forum Fanuc
    Last Post: 02-08-2010, 06:53 AM
