584,858 active members*
4,947 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > My DYNA-MYTE 3000 Revamping
Page 3 of 3 123
Results 41 to 56 of 56
  1. #41
    Quote Originally Posted by turbina View Post
    I'll contact you through PM for details
    I am also interested in a conversion box. I joined this sits just to contact you. Im not sure how to turn on private messaging. Is it possible to get one?
  2. #42
    Apr 2006
    40
    Re: My DYNA-MYTE 3000 Revamping
    On my site on the home page you can find all the contact information: email and Telephone number for Whatsapp
  3. #43
    I apologize, i am not able to find the contact information. My email is [email protected] if you dont mind contacting me so we could arrange for the purchase of a retrofit box. Thank you for you time. Hope to hear from you soon.
  4. #44
    Quote Originally Posted by A12BODYMAN View Post
    On the bottom of the page here: DMX PASSION
  5. #45
    Jun 2012
    514
    mine is still workign great 2 years later! incase you guys wanna know...like i said before...it works and is well worth the money
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
  6. #46
    Nov 2019
    Big Chips,
    I'm having some problems with my DM3000 / MACH3 / Turbina (DMX Passion) interface box setup.
    I'm experiencing random incorrect Z axis moves. When turning down the OD in several passes, randomly the tool does not return to the Z axis starting point Instead, it makes a right to left pass from where the prior right to left pass finished.
    I changed the computer and MACH software, no improvement. Issue occurs anywhere along the Z axis. The stepper drive to the lead screw is good, no loose or damaged gears.
    Tried lowering acceleration in Motor Tuning, no change.
    When manually jogging I never experience any lack of movement issues.
    I hate to give up on the project, but I'm not sure where to look next.
    Thanks for any help.
  7. #47
    Apr 2006
    40
    So if I understand correctly it seems that sometimes the movement from left to right of the Z axis is missing, to understand if the motor stall or if the movement is really missing you can hear the noise of the Z motor (motor stalled) or there is no pause during movements (no movement)?
  8. #48
    Nov 2019
    I need to confirm what action takes place. I will install a Go-Pro camera and then with be able to determine if servo is being energized or not.
    thanks for helping.
  9. #49
    Jan 2007
    Any info regarding the bidirectional tool changer? Is it just a change in the tool changer macro in mach3 or is it a firmware update?
    Daniel
  10. #50
    Apr 2006
    40
    To do into firmware
  11. #51
    Dec 2011
    34
    Interested in getting one. Sent an email to [email protected]
  12. #52
    Apr 2006
    40
    Message for FreakCNC and Ncrazyballa:
    DM3000 Old SKIP Controller is replaced by Mach3 + EZ-DM3000, the rear electrical panel does not even open, the SKIP Controller is disconnected and the EZ-DM3000 is connected, which is connected to the PC by parallel port, it does not work on the DM3000H, so far that I know not has never been tried with Mach4 or LINUX-CNC, but it should work.
    Probably the mapping of the I / O on the Distribution Board of DM3000H is different that DM3000 which has 32 outputs and 16 inputs, I think however that modifying the EZ3000 firmware can be done because the SKIP motion controller and the connection cable are identical.
    I have the DM3000H service manual but it doesn't contain the information I need, so for now I don't feel like giving you an EZ3000 because it probably won't work on the DM3000H
  13. #53
    Dec 2011
    34
    The dm3000h im going to buy comes with a maintenance manual, programing manual and another type of manual. Would the information you need to change the firmware be in one of those?
  14. #54
    Apr 2006
    40
    no, unfortunately the documentation I need is not available at the moment and trying is not very wise
  15. #55
    Apr 2006
    40
    I am happy to announce that the new updated firmware V1.62 includes add some turret calibration parameters, bidirectional rotation of the turret, parameter display with p99 and support for SYNC I / O port, for this last function you have to update the M6start.m1s macro
    user manual english pdf from my cloud:
    https://drive.google.com/file/d/1Yvc...ew?usp=sharing
    user manual italian pdf from my cloud:
    https://drive.google.com/file/d/1C7U...ew?usp=sharing
    Extra files from my cloud:
    https://drive.google.com/file/d/1KRF...ew?usp=sharing
    Last Firmware DM3000_V1.62_enc.bin from my cloud:
    https://drive.google.com/file/d/1vMM...ew?usp=sharing
  16. #56
    Apr 2006
    40
    It is advisable to add a schottky diode with low VF value, for example an SS36, to
    be able to connect the USB cable for updating the firmware and changing
    parameters even with the lathe connected
    Diode for EZ DM3000:
    https://drive.google.com/file/d/1yDZ...ew?usp=sharing
Page 3 of 3 123
  1. dyna myte 3000
    By go0869 in forum Dyna Mechtronics
    Last Post: 10-04-2014, 08:16 PM
  2. WTB Dyna Myte 3000
    By Big Chips in forum Want To Buy...Need help!
    Last Post: 09-14-2014, 06:10 PM
  3. DYNA MYTE 3000
    By SUE143 in forum Dyna Mechtronics
    Last Post: 04-09-2012, 06:00 PM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
