548,321 active members*
2,551 visitors online*
IndustryArena Forum > CAM Software > Vectric > Vetric and Black Friday
Results 1 to 17 of 17
    Registered
    Sep 2007
    140
    Any news of any black friday discounts from Vetric?
    Community Moderator ger21's Avatar
    35475
    Re: Vetric and Black Friday
    I don't think they have Black Friday in the UK.
    And I don't think I've ever seen Vectric offer discounts.
    Although 3rd party resellers often have slightly discounted prices, especially if bundled with something else.
    Registered
    Sep 2007
    140
    Yea, figured they were like festool. Take the price or leave it probably buy anyway.
    Registered
    Jan 2015
    194
    Have you looked at Fusion360? Free for personal use and businesses under $100,000 annual sales. Has built-in CAM and parametric capabilities. Some features better than VCarve and of course VCarve is better at some things. Just thought I'd bring it up for you to look at. There are some good tutorials out there on the Fusion site as well as on YouTube.
    Gold Member
    Sep 2009
    1856
    If you do lot's of signs, fusion is not there yet. If you want to machine mesh you have to convert it first before you can machine it, there is a limit to 5 Axis. No nesting yet that may be in before xmas more than likely not. other than this fusion is good to go
    I have keeped my copy of Vcarve pro and still use it, only for signs and lettering and for working on dxf before I take them into fusion.
    The one thing vectric has over fusion is if you are new to cad/cam (never used cad/cam before) Vcarve pro you can make something fancy in a hour or 2. fusion a bit longer
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Gold Member
    Jun 2004
    6618
    I agree with Daniel.
    Fusion does replace Cut 2D and 3D, but not quite ready to replace Vcarve. It is progressing and may get there one day, but Vcarve is mature now and very easy to learn. I have to relearn it every time I use it. Every couple years, but that just takes a few minutes to pick it back up.
    No reason that you can't have both though.
    Lee
    35475
    I would argue though, that Vectric products are much faster and easier to generate code for simple 2D work, provided that your drawing skills are up to par.
    But Fusion iss far more powerful, and the current price (free) is much better.
    Gold Member
    Jun 2004
    6618
    Well it will take time to get your tool library setup in Fusion as well as the learning curve, but once that time is invested, it is probably faster with Fusion.
    Save your CAM templates and all you change then are just what actual geometry the operation will work on. Takes seconds really. Incredibly fast especially if it is pretty similar to what you have done already and saved as a template.
    I haven't used Cut 2D, but do have Cut 3D and it does have some limitations that I was never pleased with. I used it much more often than Vcarve. Fusion solved every one of those limitations and added speed and ease to the process.
    You do have to invest the time though. Cut 3D can be picked up quickly.
    It's just the more that you use Fusion, the faster everything becomes.
    Lee
    Gold Member
    Sep 2009
    1856
    For 2D work it would be hard to beat Vcarve in a scratch built object if it was a level playing field. but the cam output would be better from fusion it's a Hard one if you compare both for 2D work.
    [SIGPIC][/SIGPIC]
    Gold Member
    Jun 2004
    6618
    I think Sheetcam TNG has them both beat.
    Lee
    35475
    I disagree, if your just doing basic 2D profiling.
    There isn't much you can do to make simple G1-G2-G3 moves "better".
    35475
    Gold Member
    Jun 2004
    6618
    I think speed might be the only thing you could improve with a single tool. If you had pockets and other features like slots and such, then Fusion would outdo both. It does have 2D adaptive clearing, which is very useful and quite a step up from standard pocketing strategies.
    Lee
    Gold Member
    Jan 2007
    1801
    with vectric you have every time black friday
    when you buy vectric, next week you don't have remain for electric bill, then you get the black Friday :-)
    Gold Member
    Sep 2009
    1856
    Sorry ger I meant the toolpath is faster. but it still depends on the machine. cutting the same 2D shape out in both, the fusion toolpath is just faster (a minute) and a lot better, but that's the smoothing and tool optimization doing it in fusion. I tested it useing the same model on my big machine.
    It was a visible differences on the cornering only the straight x,y and y, x moves no differences.
    also vectric is getting better at the cam side of things it's a file and machine thing.
    if the machine is well set up and does not have a stupid problem it will be different again your machine there may be no differences at all.
    [SIGPIC][/SIGPIC]
    Registered
    Jan 2015
    194
    I think VCarve is the way to go if you make lots of unrelated changes such as signs or do a project once and leave it alone. And of course picture carving would be the sole domain of VCarve. But if you build cabinets or subwoofers like I do, the parametric capabilities of Fusion 360 that allows you to change a dimension easily and automatically update the toolpath. To me this is the best feature of Fusion 360 over VCarve but I have both and will continue to pay for VCarve for the foreseeable future. But I can easily see a day where Fusion 360 exceeds VCarve but I don't see that happening anytime soon. For now, VCarve is definitely easier to use and has every feature I'd want other than the parametric capability.
    Member
    Jul 2021
    Just a few years ago, people were waiting in droves for the doors of supermarkets to open, arranging fights and fights over discounted goods. I've even heard of a case where a store employee was just trampled on Black Friday. Today, most purchases are made online. The most exciting day of shopping is not as important as it used to be. Discounts, of course, are not as large-scale as commercials and colorful signs in shop windows with crossed-out prices present to us. If you use a website where you can always find discount coupons, you can save a lot. Then you are doing the right thing because you can find reasonable offers there.
  1. Tosa Tool Black Friday Sale
    By tosatool1 in forum Knee Vertical Mills
    Last Post: 11-24-2015, 05:00 AM
  2. Black Friday or Any Friday we sell upto 70% off
    By carbidesurplus in forum Web Deals/coupons
    Last Post: 12-13-2012, 06:06 AM
  3. Black Friday - All Lasers 20% Off
    By Hurricane21 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 11-22-2011, 03:17 AM
  4. Black Friday Sale
    By MFGjosh in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2009, 09:22 PM
