Re: How does a typical CNC machine control X-Y-Z position accurately?
Originally Posted by
SouthPark
However, sensors on general CNC machines only keep track of incremental steps of a stepper motor, but those incremental steps are not a one-to-one mapping in a linear direction along a shaft (such as a ball-screw shaft) right?
Yes it is. Albeit a ratio.
With a servo, an encoder is used and a preset parameter in the controller records the amount of encoder pulses that equate to a certain degree of movement, it is known as the least input increment.
In the case of a stepper motor that generally does not have any kind of feedback device such as an encoder, the degree of movement per step of the motor equates to a recorded degree of movement, for a CNC machine to provide accurate positioning, a ball screw etc has to be machined with precision in order to maintain and preserve accurate positioning resolution based on the least input increment parameter..
Al.
Albert E.
