Originally Posted by
shas595
Clinton - G842 should be right - Not M29
This is coming straight from the Sigma 21L TS15 Programming manual:
T0800 M40
G17
M43
G28 H0
G50 C0
G97 S300 M08
G00 X62.0 Z20.0 M13
G99 G01 Z5.0 F5000
G842 G198 Z−8.0 H60.0 L6 F0.8
G80
G00 Z5.0 M05
M45
G00 X200.0 Z200.0
M01
G842 : Forward direct tapping
G843 : Reverse direct tapping
G198/G199 : Return point
X_/C_ : Hole position (Note 2)
Z_ : Z point position (Note 2)
R_ : R point position
P_ : Dwell time
L_ : No. of repetition
F_ : G98 mode Feed rate of tapping axis
G99 mode Pitch of tap
E_ : No. of thread per inch (Effective at G99 mode only)
S_ : Spindle speed of rotating tool
(Note 1) If number of repetition (L) is omitted, it deems as L=1.
If L=0 is commanded, it moves at hole position but tapping is not
performed.
(Note 2) Command a position of Z point by an axis address of tapping axis.
Command a hole position by an axis address other than tapping axis.
(Note 3) R and Z points and P are mordal during a fixed cycle.
Give it a shot!
John
