585,567 active members*
3,345 visitors online*
    Taig lathe + no Taig chucks?
    Hi. Is it possible to use a 3-jaw x 3" self-centering metal lathe chucks (K11-80 Type) with 3/4-16 back plate with Taig lathe? Or to look in the direction Sherline chucks? Thank you.
    Apr 2004
    5731
    Re: Taig lathe + no Taig chucks?
    I suppose you could do that. But why not just buy some Taig chucks? They cost less than the Sherline ones, and you don't need to fit a backplate on them.
    Andrew Werby
    Website
    Thank you. Yes, the original is of good quality and value. I bought a Taig 4-jaw self-centering Chuck. But I need the steel jaws, and grooves for larger diameters.
    Apr 2004
    5731
    Then you should get the #1030 4-jaw independent chuck: Taig Tools - Desktop Milling Machines and Lathes. . It has steel jaws that are reversible for larger diameters.
    Andrew Werby
    Website
    Yes. This chuck, I plan to take in the future. But the taig lathe I bought for small serial cilindrical parts from aluminum and steel. And not to spend too much time in accurate installation of the workpieces. I tried to work with such chuck little time. And he still prefer the original.
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. Taig or X2?
    By JohnnyVegas in forum Mini Lathe
    Last Post: 09-03-2011, 10:33 AM
  3. Soon, i will buy a taig!
    By BodaciousBrian in forum Taig Mills / Lathes
    Last Post: 02-20-2010, 03:59 AM
  4. Well... Got a Taig
    By DeusExMachina in forum Taig Mills / Lathes
    Last Post: 04-07-2009, 10:09 PM
  5. Taig CNC help
    By Grimracer in forum Taig Mills / Lathes
    Last Post: 03-14-2004, 04:32 AM
